I am unable to add my Tapo P110 smart plug to Home Assistant.
When I try to add it using the TP-Link / Tapo integration or through the Tapo Controller (HACS) integration, the setup fails immediately and I get the following error message:
Connection error: Unsupported device 192.168.100.110 of type SMART.TAPOPLUG with encrypt_scheme EncryptionScheme(is_support_https=False, encrypt_type='TPAP', http_port=80, lv=2)
Additional details:
Device model: Tapo P110
Firmware version: 1.4.0 (Build 251020 Rel.161559)
Hardware version: 1.0
The device responds in a browser (HTTP 200 OK)
It shows correctly in the Tapo app and works with no issues
Another Tapo device (P100) integrates normally with Home Assistant
Home Assistant and the P110 are on the same network
I am entering the correct local IP address: 192.168.100.110
Email and password for Tapo Cloud are correct (lowercase, no spaces)
HACS is installed and working normally
It seems like the P110 updated to a newer encryption protocol (TPAP/KLAP) and is no longer recognized by Home Assistant.
Could you please help me figure out how to integrate this device?
This solved it for me as well. Until I disabled & re-enabled Third Party Compatibility I could not add the plug.
P.S.: After updating from FW 1.4.1 to 1.4.4, all my already paired P110M stopped working with HA. Disabling & re-enabling Third Party Compatibility also fixed that, without me having to re-add them.
I seem to be having the same problem with my P110 , Tried all the above with no success update the Tapo app (3.2.2) still no joy
Ok what did work in the end was to Change password in the app which ment I had to delete all my existing plugs in Home Assistant and re-add them and this time the ones that didn’t want to add did, Not sure if there is a way to change the password in Home Assistant Tapo add-on
I was able to add back the device doing the same, but still getting an error:
Unable to connect to Tapo: Cameras Control controller: PyTapo KLAP Error #3: (‘Device connection error: 192.168.30.200: Server disconnected’, ServerDisconnectedError(‘Server disconnected’))
Unable to connect to Tapo: Cameras Control controller: PyTapo KLAP Error #3: ('Unable to query the device: 192.168.30.200: ', TimeoutError())
It was not a plug, it was a P100 camera. I managed to get it working after changing my camera password to something all lowercase and no special characters as well, just for reference
Just had this exact issue with a P110M plug. But only one of them … I have three others and a pile of P110 non matter plugs. Only one of them had this issue.
Disabling Third Party Support in the Tapo app and then re-enabling it fixed this one plug.
One of my P110 smart plugs has updated to fw 1.4.6 and now can’t get it to work in HA no matter what. The third party services toggle trick doesn’t work with it anymore. I now don’t even get a “200 OK” message anymore when putting its IP address in a browser and instead get an error saying it refused to connect with ERR_CONNECTION_REFUSED.
Same here. The update to 1.4.6 was offered for one of my P110s. Now tapo integration is unable to connect and access via browser shows ERR_CONNECTION_REFUSED.
I was able to fix it by resetting the plug and re-adding it to the tapo app. I had an authentication error in HA afterwards which could be fixed by toggling the third-party support switch in the tapo app. Now it’s working again in HA.
Edit: It seems this doesn’t survive a power outage. I had to reset it again after unplugging it.
