Unable to build container image via Dockerfile on ppc64le
I am unable to create a container image on a ppc64le architecture using the Dockerfile at GitHub - home-assistant/docker: Home Assistant containers or GitHub - home-assistant/core: Open source home automation that puts local control and privacy first.. Is there a chance to add the ppc64le architecture in the builds? What is the source of all packages on wheels (dot) home-assistant (dot) io? Could these prebuilt packages be substituted with the original source to get support?
