Unable to compile on RPi after upgrade to Builder 2024.10.0?
This test yaml compiles under x86_64 but not on my RPi5/16GB after upgrading from 2025.9.3.
esphome:
  friendly_name: testing
esp32:
  board: esp32dev
  framework:
    type: esp-idf
Actions so far:
  1. “Clean Files” from the Builder GUI
  2. Uninstall the Builder Add-On (including removing config files)
  3. Power cycle.
  4. Install Builder Add-On
Test again… This is the log:
INFO ESPHome 2025.10.0
INFO Reading configuration /config/esphome/testing.yaml...
INFO Generating C++ source...
INFO Compiling app...
Processing testing (board: esp32dev; framework: espidf; platform: https://github.com/pioarduino/platform-espressif32/releases/download/54.03.21-2/platform-espressif32.zip)
Platform Manager: Installing https://github.com/pioarduino/platform-espressif32/releases/download/54.03.21-2/platform-espressif32.zip
INFO Installing https://github.com/pioarduino/platform-espressif32/releases/download/54.03.21-2/platform-espressif32.zip
Downloading  [####################################]  100%
Unpacking  [####################################]  100%
Platform Manager: [email protected] has been installed!
INFO [email protected] has been installed!
INFO tool-esp_install not installed, installing version https://github.com/pioarduino/esp_install/releases/download/v5.3.1/esp_install-v5.3.1.zip
INFO Installing tool-esp_install version https://github.com/pioarduino/esp_install/releases/download/v5.3.1/esp_install-v5.3.1.zip
Tool Manager: Installing https://github.com/pioarduino/esp_install/releases/download/v5.3.1/esp_install-v5.3.1.zip
INFO Installing https://github.com/pioarduino/esp_install/releases/download/v5.3.1/esp_install-v5.3.1.zip
Tool Manager: [email protected] has been installed!
INFO tool-esp_install successfully installed and verified
INFO Package configuration completed successfully
Tool Manager: Installing https://github.com/pioarduino/esp-idf/releases/download/v5.4.2/esp-idf-v5.4.2.zip
INFO Installing https://github.com/pioarduino/esp-idf/releases/download/v5.4.2/esp-idf-v5.4.2.zip
Tool Manager: Installing https://github.com/pioarduino/registry/releases/download/0.0.1/xtensa-esp-elf-14.2.0_20241119.zip
INFO Installing https://github.com/pioarduino/registry/releases/download/0.0.1/xtensa-esp-elf-14.2.0_20241119.zip
Tool Manager: [email protected]+20241119 has been installed!
INFO [email protected]+20241119 has been installed!
Tool Manager: Installing https://github.com/pioarduino/registry/releases/download/0.0.1/esptoolpy-v5.0.2.zip
INFO Installing https://github.com/pioarduino/registry/releases/download/0.0.1/esptoolpy-v5.0.2.zip
Tool Manager: Installing https://github.com/pioarduino/registry/releases/download/0.0.1/mklittlefs-3.2.0.zip
INFO Installing https://github.com/pioarduino/registry/releases/download/0.0.1/mklittlefs-3.2.0.zip
Tool Manager: Installing https://github.com/pioarduino/registry/releases/download/0.0.1/cmake-3.30.2.zip
INFO Installing https://github.com/pioarduino/registry/releases/download/0.0.1/cmake-3.30.2.zip
Tool Manager: Installing https://github.com/pioarduino/registry/releases/download/0.0.1/esp-rom-elfs-20241011.zip
INFO Installing https://github.com/pioarduino/registry/releases/download/0.0.1/esp-rom-elfs-20241011.zip
Tool Manager: Installing https://github.com/pioarduino/registry/releases/download/0.0.1/ninja-1.13.1.zip
INFO Installing https://github.com/pioarduino/registry/releases/download/0.0.1/ninja-1.13.1.zip
Tool Manager: Installing https://github.com/pioarduino/registry/releases/download/0.0.1/scons-4.8.1.zip
INFO Installing https://github.com/pioarduino/registry/releases/download/0.0.1/scons-4.8.1.zip
Tool Manager: Installing platformio/tool-scons @ ~4.40801.0
INFO Installing platformio/tool-scons @ ~4.40801.0
Library Manager: Installing esphome/noise-c @ 0.1.10
INFO Installing esphome/noise-c @ 0.1.10
Library Manager: [email protected] has been installed!
Library Manager: Resolving dependencies...
INFO Resolving dependencies...
Library Manager: Installing esphome/libsodium @ 1.10020.7
INFO Installing esphome/libsodium @ 1.10020.7
INFO Installing tools via idf_tools.py (this may take several minutes)...
Tool Manager: Installing file:///root/.platformio/tools/tool-esptoolpy
INFO Installing file:///root/.platformio/tools/tool-esptoolpy
INFO Tool tool-esptoolpy successfully installed
ERROR idf_tools.py installation failed
Tool Manager: Installing file:///root/.platformio/tools/tool-mklittlefs
INFO Installing file:///root/.platformio/tools/tool-mklittlefs
INFO Tool tool-mklittlefs successfully installed
Tool Manager: Installing file:///root/.platformio/tools/tool-ninja
INFO Installing file:///root/.platformio/tools/tool-ninja
INFO Tool tool-ninja successfully installed
Tool Manager: Installing file:///root/.platformio/tools/tool-esp-rom-elfs
INFO Installing file:///root/.platformio/tools/tool-esp-rom-elfs
INFO Tool tool-esp-rom-elfs successfully installed
NOTE: the 2 x “ERROR idf_tools.py installation failed”.
Any help will be appreciated.
Regards, Martin
You might want to let them know here that they have not fixed the issue: ESPHome cannot dowland any additional packages needed to build the firmware · Issue #10934 · esphome/esphome · GitHub
