Hello - a bit stumped here - i was updating a device and couldn’t compile it. I tried compiling some other devices that had no changes and I am receiving the error below. I am able to compile if i use the framework type arduino, but it fails if i compile with the esp-idf framework (even with no changes).
Any suggestions are appreciated! I am unable to pinpoint anything from this compiler error message.
Reading CMake configuration...
-- Found Git: /usr/bin/git (found version "2.39.5")
-- git rev-parse returned 'fatal: not a git repository (or any parent up to mount point /)
Stopping at filesystem boundary (GIT_DISCOVERY_ACROSS_FILESYSTEM not set).'
-- The C compiler identification is GNU 14.2.0
-- The CXX compiler identification is GNU 14.2.0
-- The ASM compiler identification is GNU
-- Found assembler: /data/cache/platformio/packages/toolchain-xtensa-esp-elf/bin/xtensa-esp32-elf-gcc
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Check for working C compiler: /data/cache/platformio/packages/toolchain-xtensa-esp-elf/bin/xtensa-esp32-elf-gcc - skipped
-- Detecting C compile features
-- Detecting C compile features - done
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Check for working CXX compiler: /data/cache/platformio/packages/toolchain-xtensa-esp-elf/bin/xtensa-esp32-elf-g++ - skipped
-- Detecting CXX compile features
-- Detecting CXX compile features - done
-- Building ESP-IDF components for target esp32
-- Configuring incomplete, errors occurred!
CMake Error at /data/cache/platformio/packages/framework-espidf/tools/cmake/build.cmake:620 (message):
File "<frozen runpy>", line 189, in _run_module_as_main
File "<frozen runpy>", line 112, in _get_module_details
File "/root/.platformio/penv/.espidf-5.4.2/lib/python3.12/site-packages/idf_component_manager/__init__.py", line 6, in <module>
from idf_component_tools.environment import ComponentManagerSettings
File "/root/.platformio/penv/.espidf-5.4.2/lib/python3.12/site-packages/idf_component_tools/__init__.py", line 9, in <module>
if ComponentManagerSettings().DEBUG_MODE:
File "/root/.platformio/penv/.espidf-5.4.2/lib/python3.12/site-packages/pydantic_settings/main.py", line 193, in __init__
super().__init__(
File "/root/.platformio/penv/.espidf-5.4.2/lib/python3.12/site-packages/pydantic/main.py", line 250, in __init__
validated_self = self.__pydantic_validator__.validate_python(data, self_instance=self)
File "/root/.platformio/penv/.espidf-5.4.2/lib/python3.12/site-packages/idf_component_tools/environment.py", line 148, in fallback_to_default
if field.validation_alias:
AttributeError: 'NoneType' object has no attribute 'validation_alias'
Call Stack (most recent call first):
/data/cache/platformio/packages/framework-espidf/tools/cmake/project.cmake:718 (idf_build_process)
CMakeLists.txt:3 (project)
========================== [FAILED] Took 6.95 seconds ==========================
