HA is unable to configure the 2 aircons. Daikin AC is failing to connect ( “Connect call failed” ) to the IP addresses. Can you help ?
Which model Wifi adaptor does your Daikin unit have?
Is it on the supported hardware list?
Hi Tom, from the app Onecta, I see that the Gateway Wlan is on BRP069B4x for both the aircons. This adaptor seems to be the latest model used by Daikin so sd be fine.
Anyhow, I have just noted that the IP addresses of the 2 aircons shown on both the router and Onecta are different from those shown on Home Assistant: I copy below what HA states abt these IPs, dont know where HA has found these wrong IP addresses:
Richiede attenzione
- 10.0.0.13
1 dispositivo e 12 entità
Configurazione non riuscita, riproverà: Cannot connect to host 10.0.0.13:80 ssl:default [Connect call failed (‘10.0.0.13’, 80)]
HA is going in loop to try and connect to these strange IP addresses. I had modified the IP addresses ( from Rename this configuration ) stating those taken from the router but doesnt wor. Dont know how to solve…
Yeah that is strange. I’ve never heard of them having two ip addresses.
Maybe if you open an issue here the developer can help.
https://github.com/home-assistant/core/issues?q=is%3Aissue+is%3Aopen+label%3A"integration%3A+daikin"
Hi Tom, I made it easier: deleted the 2 Daikin aircons and uploaded again from scratch. Now all is working. Tks anyway.
