Unable to configure the remote access via SSH (Terminal & SSH Add-on)
Hi all,
Starting from default setting in the Add-On I see a strange message in the Log: “WARNING: SSH port is disabled. Prevent start of SSH server.” and I also have this setting on the Network menu it seems the port 22 is disabled
If I put any port there (also the 22) i get the following log: in which the strange part to me is: cont-init: info: running /etc/cont-init.d/ssh.sh
[19:35:35] FATAL: You need to setup a login!
Full log:
[18:35:26] INFO: Service restart after closing
s6-rc: info: service legacy-services successfully stopped
s6-rc: info: service legacy-cont-init: stopping
s6-rc: info: service legacy-cont-init successfully stopped
s6-rc: info: service fix-attrs: stopping
s6-rc: info: service fix-attrs successfully stopped
s6-rc: info: service s6rc-oneshot-runner: stopping
s6-rc: info: service s6rc-oneshot-runner successfully stopped
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
cont-init: info: running /etc/cont-init.d/apks.sh
cont-init: info: /etc/cont-init.d/apks.sh exited 0
cont-init: info: running /etc/cont-init.d/keygen.sh
[19:35:33] INFO: Restoring host keys…
cont-init: info: /etc/cont-init.d/keygen.sh exited 0
cont-init: info: running /etc/cont-init.d/profile.sh
cont-init: info: /etc/cont-init.d/profile.sh exited 0
cont-init: info: /etc/cont-init.d/ssh.sh exited 1
cont-init: warning: some scripts exited nonzero
s6-rc: warning: unable to start service legacy-cont-init: command exited 1
/run/s6/basedir/scripts/rc.init: warning: s6-rc failed to properly bring all the services up! Check your logs (in /run/uncaught-logs/current if you have in-container logging) for more information.
/run/s6/basedir/scripts/rc.init: fatal: stopping the container.
I also tried to input in the Server configuration YAML:
username: “XXX”
password: “YYY”
but the SSH connection is always refused, Any clue?
Thanks in advance
Hi all, I saw no feedback :-(, anyway I rsolved installing the Advanced WEB&SSH Add-On. Probably something wrong with the standard Web & SSH version I stopped.
