Last night I attempted to upgrade to 75.2 from 75.0, the web interface never came back. I could still see files on the raspberry pi using samba. I powercycled the pi but that didn’t seem to do anything. I ended up reflashing the home assistant image to the sd card and everything was fine again. Tonight I rebooted home assistant and I get the same problem. Unable to connect but I can see the files. Here’s what’s in the homeassistant.log file:
2018-08-08 21:29:27 WARNING (Recorder) [homeassistant.components.recorder] Ended unfinished session (id=4 from 2018-08-09 00:57:45.162273)
2018-08-08 21:29:50 WARNING (MainThread) [homeassistant.setup] Setup of config is taking over 10 seconds.
2018-08-08 21:30:34 ERROR (SyncWorker_0) [pychromecast.socket_client] Failed to connect, retrying in 5.0s
2018-08-08 21:30:34 WARNING (MainThread) [homeassistant.setup] Setup of mqtt is taking over 10 seconds.
I’m facing the absolute same issue.
Even deleting all configuration and letting home assistant generate a new default set will not bring the front end up.
I ended in flashing a new SDCard. But after the second reboot the issue is there again.
I did originally a few months ago via the discovery feature, this second time I did the same thing and it was probably the last step I did before the last reboot. Does setting it up via Yaml work better?
I did a fresh install and it keeps happing to me
Delete the core.config.entities in the storage folder and reboot.
This allowed me back into the front page
