Unable to connect to HA from Android 6
Hi everyone!
I have a weird problem I can’t fix.
I’ve supervised HA installed on the RPI 4b, ubuntu. I can connect to HA from my home network from PC / IOS, but cannot connect using any of my tablets that runs Android 6. When I try to use companion app or chrome to do this, I get to authorize screen. After authorization I see slow loading of top blue panel of the frontend screen and it stucks there(with unable to connect error for app and no error for chrome).
I’ve tried connect through home network ip address (192.168.1.75:8123) and get described results.
I also tried connect throught dataplicity, this gives the same result.
It also kinda work when I use nabu casa to connect, but slower then local connect.
Also I should mention that both tablets was working with HA before. Not sure when it started.
Did anyone had the same problems?
