Unable to connect via Web / WiFi
As of up 2025.2.3 (and still with 2025.2.4), I have not been able to connect to my HA instance via my phone or tablet either via WiFi or cellular. I can still connect via my computer (wired). I haven’t made any network changes and my HA instance is connected via wired to my network.
I get the following warning messages in my logs:
Logger: homeassistant.components.websocket_api.http.connection
Source: components/websocket_api/http.py:533
integration: Home Assistant WebSocket API (documentation, issues)
First occurred: February 15, 2025 at 1:43:30 PM (86 occurrences)
Last logged: 9:34:12 AM
[546999480480] Paul Leppert from 172.59.225.235 (Home Assistant/2025.1.2-14946 (Android 13; Pixel 4a)): Disconnected: Received error message during command phase:
[547658154624] Paul Leppert from 172.59.225.235 (Home Assistant/2025.1 (io.robbie.HomeAssistant; build:2025.1073; iPadOS 18.3.1)): Disconnected: Received error message during command phase:
[547035289856] Paul Leppert from 172.59.225.235 (Home Assistant/2025.1 (io.robbie.HomeAssistant; build:2025.1073; iPadOS 18.3.1)): Disconnected: Received error message during command phase:
[547035286544] Paul Leppert from 172.59.225.235 (Home Assistant/2025.1.2-14946 (Android 13; Pixel 4a)): Disconnected: Received error message during command phase:
[546878863488] Paul Leppert from 172.59.225.235 (Home Assistant/2025.1.2-14946 (Android 13; Pixel 4a)): Disconnected: Received error message during command phase:
I don’t see any relevant errors in the logs (the above are warnings).
In my phone / iPad app, I get the “Unable to connect to Home Assistant”
I’m not sure what to do to troubleshoot this. Any ideas?
