I have some new color lights (Lumary Smart Disk Light B1), linked via Tuya. They show up in the Dashboard, and I can click the icons, and select Color and set the color, and this works great. I can also put the lights in scenes, an so long as all scenes specify colors, they work fine too. However, if I use the dashboard button and set the light to a color temperature (white), or have a scene which does the same, the color scenes no longer work - they leave the light in color temperature mode (white).
Also, when I then use the scene editor, all the colors I have configured are converted to white. If I save the scene, the color settings are lost. (I think this is because the scene editor starts by commanding the devices to the current scene values, then retrieving current state. Since the commands to use color don’t work, the state returned is now color temperature.)
If I leave the scenes intact, I can go to the dashboard, use the button and manually set the light to a color. Then the color scenes will work fine, until something commands the light to a color temperature again.
I also tried creating a script to command the light to a color, and using that in my automations before the scene. But the script also doesn’t seem to be able to get the light out of color temperature mode.
To test this out, I made three scenes: White, Red and Green, each just for the same light. I can change between Red and Green as much as I want, and it works fine. But as soon as I command to White, it won’t change to Red or Green anymore. But If I use the Dashboard button, I can change it to a color, and then Red and Green resume working.
This is from my scenes.yaml:
- id: '1670563097431'
entities:
light.lumary_smart_disk_light_b1_4:
min_color_temp_kelvin: 2000
max_color_temp_kelvin: 6535
min_mireds: 153
max_mireds: 500
supported_color_modes:
- brightness
- color_temp
- hs
color_mode: hs
brightness: 43
hs_color:
- 330
- 100
rgb_color:
- 255
- 0
- 127
xy_color:
- 0.581
- 0.245
friendly_name: Mikey
supported_features: 0
state: 'on'
metadata: {}
- id: '1670563139957'
entities:
min_mireds: 153
max_mireds: 500
- brightness
- color_temp
- hs
color_mode: hs
brightness: 43
hs_color:
- 135
- 100
rgb_color:
- 0
- 255
- 63
xy_color:
- 0.17
- 0.703
state: 'on'
metadata: {}
- id: '1670563163556'
entities:
min_mireds: 153
max_mireds: 500
- brightness
- color_temp
- hs
color_mode: color_temp
brightness: 43
hs_color:
- 26.895
- 37.733
rgb_color:
- 255
- 201
- 158
xy_color:
- 0.431
- 0.367
color_temp_kelvin: 3846
color_temp: 260
state: 'on'
metadata: {}
