Having same issue. My exsisting config stopped working after the latests update. Now I get these errors
2020-06-10 15:16:41 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
File "/usr/local/lib/python3.7/site-packages/homeassistant/data_entry_flow.py", line 129, in async_init
flow, flow.init_step, data, init_done
File "/usr/local/lib/python3.7/site-packages/homeassistant/data_entry_flow.py", line 201, in _async_handle_step
result: Dict = await getattr(flow, method)(user_input)
File "/usr/local/lib/python3.7/site-packages/homeassistant/components/owntracks/config_flow.py", line 56, in async_step_import
webhook_id, _webhook_url, cloudhook = await self._get_webhook_id()
File "/usr/local/lib/python3.7/site-packages/homeassistant/components/owntracks/config_flow.py", line 70, in _get_webhook_id
if self.hass.components.cloud.async_active_subscription():
File "/usr/local/lib/python3.7/site-packages/homeassistant/loader.py", line 459, in __getattr__
component: Optional[ModuleType] = integration.get_component()
File "/usr/local/lib/python3.7/site-packages/homeassistant/loader.py", line 264, in get_component
cache[self.domain] = importlib.import_module(self.pkg_path)
File "/usr/local/lib/python3.7/importlib/__init__.py", line 127, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File "<frozen importlib._bootstrap>", line 1006, in _gcd_import
File "<frozen importlib._bootstrap>", line 983, in _find_and_load
File "<frozen importlib._bootstrap>", line 967, in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 677, in _load_unlocked
File "<frozen importlib._bootstrap_external>", line 728, in exec_module
File "<frozen importlib._bootstrap>", line 219, in _call_with_frames_removed
File "/usr/local/lib/python3.7/site-packages/homeassistant/components/cloud/__init__.py", line 4, in <module>
from hass_nabucasa import Cloud
File "/var/opt/homeassistant/deps/lib/python3.7/site-packages/hass_nabucasa/__init__.py", line 19, in <module>
from .remote import RemoteUI
File "/var/opt/homeassistant/deps/lib/python3.7/site-packages/hass_nabucasa/remote.py", line 16, in <module>
from .acme import AcmeClientError, AcmeHandler
File "/var/opt/homeassistant/deps/lib/python3.7/site-packages/hass_nabucasa/acme.py", line 9, in <module>
import OpenSSL
File "/var/opt/homeassistant/deps/lib/python3.7/site-packages/OpenSSL/__init__.py", line 8, in <module>
from OpenSSL import crypto, SSL
File "/var/opt/homeassistant/deps/lib/python3.7/site-packages/OpenSSL/crypto.py", line 15, in <module>
from OpenSSL._util import (
File "/var/opt/homeassistant/deps/lib/python3.7/site-packages/OpenSSL/_util.py", line 6, in <module>
from cryptography.hazmat.bindings.openssl.binding import Binding
File "/usr/local/lib/python3.7/site-packages/cryptography/hazmat/bindings/openssl/binding.py", line 16, in <module>
from cryptography.hazmat.bindings._openssl import ffi, lib
ImportError: /usr/local/lib/python3.7/site-packages/cryptography/hazmat/bindings/_openssl.abi3.so: undefined symbol: d2i_DHxparams
