Hi, since a few weeks my snapshot function is no longer working.
When I try t do a manual snapshot nothing happens even after some hours, I’m running on 0.81.6 in docker on a NUC and everything else works flawlessly.
From the hassio’s system tab I can view that the snapshot process begins but never ends, my last snapshot was done a few weeks ago and worked without problems.
18-11-06 18:04:41 INFO (MainThread) [hassio.snapshots] Full-Snapshot 9d0e41a4 start
18-11-06 18:04:41 INFO (MainThread) [hassio.snapshots] Snapshot 9d0e41a4 store Add-ons
18-11-06 18:04:41 INFO (MainThread) [hassio.addons.addon] Build snapshot for add-on core_letsencrypt
18-11-06 18:04:41 INFO (MainThread) [hassio.addons.addon] Build snapshot for add-on e5829d31_ps4waker
18-11-06 18:04:41 INFO (MainThread) [hassio.addons.addon] Build snapshot for add-on a0d7b954_influxdb
18-11-06 18:04:41 INFO (MainThread) [hassio.addons.addon] Finish snapshot for addon a0d7b954_plex
18-11-06 18:04:41 INFO (MainThread) [hassio.addons.addon] Build snapshot for add-on core_samba
18-11-06 18:04:41 INFO (MainThread) [hassio.addons.addon] Build snapshot for add-on a0d7b954_ide
18-11-06 18:04:41 INFO (MainThread) [hassio.addons.addon] Build snapshot for add-on a0d7b954_nodered
18-11-06 18:04:41 INFO (MainThread) [hassio.addons.addon] Build snapshot for add-on 69bb46cb_deconz
18-11-06 18:04:41 INFO (MainThread) [hassio.addons.addon] Build snapshot for add-on core_mosquitto
18-11-06 18:04:41 INFO (MainThread) [hassio.addons.addon] Build snapshot for add-on a0d7b954_pi-hole
18-11-06 18:04:41 INFO (MainThread) [hassio.addons.addon] Build snapshot for add-on a0d7b954_sonweb
18-11-06 18:04:41 INFO (MainThread) [hassio.addons.addon] Finish snapshot for addon e5829d31_ps4waker
18-11-06 18:04:41 INFO (MainThread) [hassio.addons.addon] Finish snapshot for addon core_samba
18-11-06 18:04:41 INFO (MainThread) [hassio.addons.addon] Finish snapshot for addon a0d7b954_nodered
18-11-06 18:04:41 INFO (MainThread) [hassio.addons.addon] Finish snapshot for addon core_mosquitto
18-11-06 18:04:41 INFO (MainThread) [hassio.addons.addon] Finish snapshot for addon a0d7b954_sonweb
18-11-06 18:04:41 INFO (MainThread) [hassio.addons.addon] Finish snapshot for addon 69bb46cb_deconz
18-11-06 18:04:41 INFO (MainThread) [hassio.addons.addon] Finish snapshot for addon core_letsencrypt
18-11-06 18:04:41 INFO (MainThread) [hassio.addons.addon] Finish snapshot for addon a0d7b954_ide
18-11-06 18:05:52 INFO (MainThread) [hassio.addons.addon] Finish snapshot for addon a0d7b954_pi-hole
18-11-06 18:05:57 INFO (MainThread) [hassio.addons.addon] Finish snapshot for addon a0d7b954_influxdb
18-11-06 18:05:57 INFO (MainThread) [hassio.snapshots] Snapshot 9d0e41a4 store folders
18-11-06 18:05:57 INFO (SyncWorker_6) [hassio.snapshots.snapshot] Snapshot folder homeassistant
18-11-06 18:05:57 INFO (SyncWorker_10) [hassio.snapshots.snapshot] Snapshot folder addons/local
18-11-06 18:05:57 INFO (SyncWorker_19) [hassio.snapshots.snapshot] Snapshot folder ssl
18-11-06 18:05:57 INFO (SyncWorker_17) [hassio.snapshots.snapshot] Snapshot folder share
18-11-06 18:05:57 INFO (SyncWorker_10) [hassio.snapshots.snapshot] Snapshot folder addons/local done
18-11-06 18:05:57 INFO (SyncWorker_19) [hassio.snapshots.snapshot] Snapshot folder ssl done
18-11-06 18:11:52 INFO (MainThread) [hassio.snapshots] Found 2 snapshot files
18-11-06 18:12:24 INFO (SyncWorker_6) [hassio.snapshots.snapshot] Snapshot folder homeassistant done
18-11-06 18:16:20 INFO (MainThread) [hassio.snapshots] Found 2 snapshot files
The snapshot button is not grayed but if I press it the system tells me that the last snapshot is still running.
18-11-06 18:50:37 ERROR (MainThread) [hassio.snapshots] A snapshot/restore process is already running
18-11-06 18:52:31 INFO (MainThread) [hassio.snapshots] Found 2 snapshot files
Even browsing to the backup location shows nothing so is not a problem of the GUI not refreshing.
I don’t get it. I am getting now the same issue… The only way for me to work is to save something under the /config/www folder, could be as well /config/www/tmp (if I created the folder).
Everytime I try somewhere else like /tmp it does not work. Knowing of course I have in my config:
I actually found out that the problem was the folder mounted in hassio/shares with movies for plex to work. When the snapshot system tried to back up the shares folder, it failed because the folder is shared from another disk and the main ssd of my NUC is small and can’t backup everything. I resolved by requesting a snapshot without the shares backup and now everything works again.
I have the same issue but nothing is locking folders or files. Directly after a restart I started a snapshot and got this :
core-ssh:~# hassio sn new --name test
Error:
core-ssh:~#
The logs said this:
INFO (MainThread) [hassio.api.security] /snapshots/new/full access from core_ssh
I don’t know where to go from here to fix this, does anyone have an idea?
I was having the same problems recently. The problem is that once I click on the “Create” button on the UI, I get no feedback whatsoever that the backup process has started. If a check the logs, I can see that it backups for eg. the addons, 19-04-19 15:28:18 INFO (MainThread) [hassio.addons.addon] Finish snapshot for addon a0d7b954_grafana
but the process seems to never end. I also tried with the cli interface, with the “hassio snapshots new” command.
It turned out that you HAVE to wait until you get one of these responses: 19-04-19 15:39:17 INFO (MainThread) [hassio.snapshots] Full-Snapshot 166c141c done -in the logs
OR core-ssh:~# hassio snapshots new slug: 166c141c
-through ssh.
Otherwise your backup is still going on, and you should not terminate it in any way. My only issue is now that it takes an awful lot of time, probably because of the hardware limitations of my raspberry.
@ptrsz - The only problem I have with this solution is that It’s been a couple days since I last created a backup, so there is no backup process currently running.
