I’ve installed the influx addon and set it up, but it doesn’t appear to be running correctly.
I’ve set up the database, username and password and also amended the configuration.yaml file, which all seems to be quite straightforward. But when I click on ‘Explore’ ‘homeassisant.autogen’ there’s no drop-down list of measurements that indicates that the database is being populated.
The addon log is quite busy, but eventually stops with an error: ‘Failed to get a0d7b954_influxdb logs, Error in input stream’.
I’m at a loss as to where to start looking for the problem and would be grateful for some guidance please.
Jim
My influxDB credentials are consistent across the addon, including the configuration.yaml.
The UI logs aren’t much help, but ssh’ing into the Pi to check the homeassistant.log I see:
ERROR (SyncWorker_3) [homeassistant.components.influxdb] Cannot connect to InfluxDB due to 'HTTPConnectionPool(host='192.168.1.5', port=8086): Max retries exceeded with url: /write?db=homeassistant (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x7f585606e0>: Failed to establish a new connection: [Errno 111] Connection refused'))'. Please check that the provided connection details (host, port, etc.) are correct and that your InfluxDB server is running and accessible. Retrying in 60 seconds.
The logs show errors such as:
“Cannot connect to InfluxDB due to ‘HTTPConnectionPool(host=‘https’, port=80): Max retries exceeded with url: /*******.duckdms.org:8086/write?db=homeassistant (Caused by NewConnectionError(’<urllib3.connection.HTTPConnection object at 0x7f4d18c8c0>: Failed to establish a new connection: [Errno -5] Name has no usable address’))'. Please check that the provided connection details (host, port, etc.) are correct and that your InfluxDB server is running and accessible. Retrying in 60 seconds.”
This is the relevant entry in my homeassistant.yaml file:
I tried http://homeassistant.local for the internal url, but it didn’t make any difference. I’ve had Duckdns and Let’s Encrypt running without problems for several months now without other problems, but I suspect that Duckdns may be causing this problem.
(I’m mystified why the error log gave an incomplete url!)
… Or check the IP on your router and use that one. Supposing you set a static local IP for your HA as it is recommended
And another hint - you have to use the addon without SSL. Or have… I don’t know but with SSL it does not work for me
(you can disable it in the influx DB configuration)
