Hi everyone, trying to work out what to do here. I have a Shelly unit set up to undertake a GET
request from my HA server.
I’m using the following script, which calls the REST API with the token (redacted), then logs the response to the console.
Shelly.call(
"HTTP.GET",
url: "http://192.168.XXX.XXX:8123/api/",
headers: {
"Authorization": "Bearer TOKEN_REDACTED",
"Content-Type": "application/json"
function(response) {
console.log(response);
But when I run the script, HA logs the following:
2025-02-10 20:25:33.780 WARNING (MainThread) [homeassistant.components.http.ban] Login attempt or request with invalid authentication from shellyplus2pm-MAC_ADDR.local (192.168.XXX.XXX). Requested URL: '/api/'. (Plus2PM/1.4.4 (ShellyOS))
On the Shelly side, I get the following response from the HA server:
"Date": "Mon, 10 Feb 2025 09:34:11 GMT",
"Referrer-Policy": "no-referrer",
"Server": "",
"X-Content-Type-Options": "nosniff",
"X-Frame-Options": "SAMEORIGIN"
"body": "401: Unauthorized"
Initially I thought there might be something weird going with my token. So I ran the same GET
request via cURL
and I got a completely valid response.
Why would I be getting a 401 error in this case?
