Hey all,
I have been going around in circles with trying to link my TrueNAS Scale Home Assistant instance to Cloudflare to find out I have not got the right version with add-ons and so needed to spin up a VM to run the Supervised version.
I have debian running on my VM in TrueNAS and have managed to install the OS 1.6.0.
I have verified this with the command in debian and can see it there.
however when I then try the following command i get the error below
dpkg -i homeassistant-supervised.deb
error processing archive homeassistant-supervised.deb (–install):
pre-dependency problem - not installing homeassistant-supervised
Errors were encountered while processing:
I am running the commands under the SU (root) but this is still giving me this error.
I tried removing the downlaod and trying again but I get the same error time and time again.
Any help would be amazing
Not a huge linix user so be kind!
