Just set up a zooz 800 in Home Assistant. After a lot of struggle I finally get it to work once for maybe 20 minutes. Now I just get
19:43:50] INFO: Successfully send discovery information to Home Assistant.
2025-05-19T23:43:52.142Z DRIVER ███████╗ ██╗ ██╗ █████╗ ██╗ ██╗ ███████╗ ██╗ ███████╗
2025-05-19T23:43:52.144Z DRIVER version 15.3.2
2025-05-19T23:43:52.145Z DRIVER
2025-05-19T23:43:53.426Z CONFIG version 15.3.2
2025-05-19T23:43:54.248Z CNTRLR querying Serial API capabilities...
2025-05-19T23:43:55.439Z DRIVER Failed to initialize the driver: ZWaveError: Timeout while waiting for an ACK
from the controller (ZW0200)
at Driver.sendMessage (file:///usr/src/node_modules/zwave-js/src/lib/drive
r/Driver.ts:6965:23)
at ZWaveController.queryCapabilities (file:///usr/src/node_modules/zwave-j
s/src/lib/controller/Controller.ts:1061:37)
at Driver.initializeControllerAndNodes (file:///usr/src/node_modules/zwave
-js/src/lib/driver/Driver.ts:1913:46)
at Immediate.<anonymous> (file:///usr/src/node_modules/zwave-js/src/lib/dr
iver/Driver.ts:1639:16)
Error in driver ZWaveError: Failed to initialize the driver: ZWaveError: Timeout while waiting for an ACK from the controller (ZW0200)
at Driver.sendMessage (file:///usr/src/node_modules/zwave-js/src/lib/driver/Driver.ts:6965:23)
at ZWaveController.queryCapabilities (file:///usr/src/node_modules/zwave-js/src/lib/controller/Controller.ts:1061:37)
at Driver.initializeControllerAndNodes (file:///usr/src/node_modules/zwave-js/src/lib/driver/Driver.ts:1913:46)
at Immediate.<anonymous> (file:///usr/src/node_modules/zwave-js/src/lib/driver/Driver.ts:1639:16) (ZW0100)
at Immediate.<anonymous> (file:///usr/src/node_modules/zwave-js/src/lib/driver/Driver.ts:1659:6) {
code: 100,
context: undefined,
transactionSource: undefined
Shutting down
[23:43:55] WARNING: Halt add-on
s6-rc: info: service legacy-services: stopping
s6-rc: info: service legacy-services successfully stopped
s6-rc: info: service legacy-cont-init: stopping
s6-rc: info: service legacy-cont-init successfully stopped
s6-rc: info: service fix-attrs: stopping
s6-rc: info: service fix-attrs successfully stopped
s6-rc: info: service s6rc-oneshot-runner: stopping
s6-rc: info: service s6rc-oneshot-runner successfully stopped
This is on a VM in Proxmox. I’ve tried forwarding the port and the device with the same results. Home Assistant sees the device in hardware and I’m able to select it in the drop down of the config page for the Addon. I’ve tried dozens of restarts and moving it to all different ports. I’ve also tried with and without an extention cord. Finally I tried fully uninstalling and readding the addon but same results. I have no idea what else to try.
