I have forked this repo and changed some colors in the thermostat-dark-card.ts file and uploaded it to my forked repo. Now, when I try to add this repo in HACS, I get “Repostitory structure is not compliant)”. How can I fix this?
Have you looked at the docs for making the repo HACS compliant?
No, because 1) I didn’t change anything other than a few hex color values 2) couldn’t find the documentation
I’m not saying that I know what the problem is but at least it’s a good place to start.
You most probably have hard coded references to the original repo in json files so you will need to comb through the other files to update the repo names. Then it should work.
Thank you for your suggestion. I replaced all the references to the original repo with mine but the error still occurs. Could you take a look if it’s not too much of a hassle? Here is the link.
