I installed the add-on Get HACS. I’ve followed the installation steps several times but get stuck on step 3 where it says the next steps are in the add-on log file. I’ve included the add-on log file below, I don’t see any further instructions. I’ve restarted HA and still nothing. I found another thread indicating there are no instruction in the log, but that did not help either.
Can anyone tell me what I’m missing?
HACS install: No instructions in log - Third party integrations - Home Assistant Community
Instructions
- Use the Install button above to build the add-on.
- Start the add-on.
- Navigate to the add-on logs and follow the instructions given there.
LOG FILE:
[08:51:04] INFO: ------------------------------------
[08:51:04] INFO: Starting HACS download…
[08:51:04] INFO: Channel: current
Connecting to raw.githubusercontent.com (185.199.108.133:443)
saving to ‘./get-hacs’
get-hacs 100% || 4990 0:00:00 ETA
‘./get-hacs’ saved
INFO: Trying to find the correct directory…
INFO: Found Home Assistant configuration directory at ‘/homeassistant’
INFO: Changing to the custom_components directory…
INFO: Downloading HACS
Connecting to github.com (140.82.113.3:443)
Connecting to release-assets.githubusercontent.com (185.199.111.133:443)
saving to ‘hacs.zip’
hacs.zip 24% |******* | 4636k 0:00:03 ETA
hacs.zip 92% | | 16.8M 0:00:00 ETA
hacs.zip 100% |*****************************| 18.1M 0:00:00 ETA
‘hacs.zip’ saved
WARN: HACS directory already exist, cleaning up…
INFO: Creating HACS directory…
INFO: Unpacking HACS…
INFO: Verifying versions
INFO: Current version is 2025.10.1, minimum version is 2024.4.1
INFO: Removing HACS zip file…
INFO: Installation complete.
INFO: Remember to restart Home Assistant before you configure it
s6-rc: info: service legacy-services: stopping
s6-rc: info: service legacy-services successfully stopped
s6-rc: info: service legacy-cont-init: stopping
s6-rc: info: service legacy-cont-init successfully stopped
s6-rc: info: service fix-attrs: stopping
s6-rc: info: service fix-attrs successfully stopped
s6-rc: info: service s6rc-oneshot-runner: stopping
s6-rc: info: service s6rc-oneshot-runner successfully stopped
