I followed the instructions here: GitHub - home-assistant/supervised-installer: Installer for a generic Linux system
But getting the following error:
$ sudo apt install ./homeassistant-supervised.deb
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
Note, selecting 'homeassistant-supervised' instead of './homeassistant-supervised.deb'
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
homeassistant-supervised : Depends: os-agent but it is not installable
E: Unable to correct problems, you have held broken packages.
$ sudo apt install os-agent -y
E: Unable to locate package os-agent
This is with a clean install of Debian, on a fresh drive. The only other thing I installed manually was sudo
and I added my own user account.
