Unable to install python_openzwave 0.4.0.31
He Guys,
I somehow cannot install python_openzwave 0.4.0.31.
Ik tried to install 0.4.0.34 and this went without any issues. Could this has to do something with cached files?
I already removed all the .pyc files in the /srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/ folders.
Ik hope you can help me out here.
The installation returned this error
Collecting python_openzwave==0.4.0.31
Exception:
  File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/pip/basecommand.py", line 215, in main
    status = self.run(options, args)
  File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/pip/commands/install.py", line 335, in run
    wb.build(autobuilding=True)
  File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/pip/wheel.py", line 749, in build
    self.requirement_set.prepare_files(self.finder)
  File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/pip/req/req_set.py", line 380, in prepare_files
    ignore_dependencies=self.ignore_dependencies))
  File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/pip/req/req_set.py", line 620, in _prepare_file
    session=self.session, hashes=hashes)
  File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/pip/download.py", line 809, in unpack_url
    unpack_file_url(link, location, download_dir, hashes=hashes)
  File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/pip/download.py", line 715, in unpack_file_url
    unpack_file(from_path, location, content_type, link)
  File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/pip/utils/__init__.py", line 599, in unpack_file
    flatten=not filename.endswith('.whl')
  File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/pip/utils/__init__.py", line 484, in unzip_file
    zip = zipfile.ZipFile(zipfp, allowZip64=True)
  File "/usr/lib/python3.4/zipfile.py", line 937, in __init__
    self._RealGetContents()
  File "/usr/lib/python3.4/zipfile.py", line 1006, in _RealGetContents
    raise BadZipFile("Bad magic number for central directory")
zipfile.BadZipFile: Bad magic number for central directory
Ok, I just fixed it.
I had to add ‘–no-cache-dir’ to the command and a new version of the package was downloaded.
