I am new to the Home Assistant community so if I am posting wrong please let me know.
I installed HACS successfully and have followed the install instructions (I hope). The issue I have is when I go to add a new integration, the Wyze integration does not show up when I search for it. What am I doing wrong?
not sure which integration you’re trying to install from HACS. From what I’ve read, if you’re trying to get cameras into HA, I don’t think you can directly. Currently, I have tinyCam Monitor Pro on my Nvidia Shield (any Android device that is can run 24/7 should work) and it has a built in webserver to stream out the video, which I’ve added using the MJPEG IP Camera integration.
Wyze is showing on mine, with an update from two weeks ago. Maybe the entire store takes a while to download? Have you got the right depositories defined?
Try re-downliadung HACS to refresh it if it is not showing by now.
