Unable to join Sengled E13-N11 to Zigbee network
Hello everyone
I have 4 Sengled E13-N11 bulbs and three of them joined the Z2M network without a problem. However one refuses to do so - I tried the reset/standard joining method - turn on/off the bulb 5-10 times. It does not even go into pairing mode by flashing just stays powered on and after some time just turns itself off even when power is on.
If turn off and then on - the lamp stays on, but the repeated attempts to join to network exhibits the same behavior.
Any idea what might cause this?
probably the zigbee chip is just dead… time for a RMA :slight_smile:
