Hi all, I just got home and noticed that my automations were not running. So I looked at the HA docker logs in Portainer and saw the messages shown below. This seems to prevent HA from launching. Has anyone a clue as to what I should do with this? Thank you in advance!
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service legacy-services: starting
services-up: info: copying legacy longrun home-assistant (no readiness notification)
s6-rc: info: service legacy-services successfully started
2024-01-20 17:33:30.601 ERROR (MainThread) [root] Uncaught exception
File "<frozen runpy>", line 198, in _run_module_as_main
File "<frozen runpy>", line 88, in _run_code
File "/usr/src/homeassistant/homeassistant/__main__.py", line 221, in <module>
sys.exit(main())
File "/usr/src/homeassistant/homeassistant/__main__.py", line 209, in main
exit_code = runner.run(runtime_conf)
File "/usr/src/homeassistant/homeassistant/runner.py", line 188, in run
return loop.run_until_complete(setup_and_run_hass(runtime_config))
File "/usr/local/lib/python3.11/asyncio/base_events.py", line 653, in run_until_complete
return future.result()
File "/usr/src/homeassistant/homeassistant/runner.py", line 154, in setup_and_run_hass
hass = await bootstrap.async_setup_hass(runtime_config)
File "/usr/src/homeassistant/homeassistant/bootstrap.py", line 147, in async_setup_hass
config_dict = await conf_util.async_hass_config_yaml(hass)
File "/usr/src/homeassistant/homeassistant/config.py", line 501, in async_hass_config_yaml
await merge_packages_config(hass, config, core_config.get(CONF_PACKAGES, {}))
File "/usr/src/homeassistant/homeassistant/config.py", line 1029, in merge_packages_config
PACKAGES_CONFIG_SCHEMA(packages)
File "/usr/src/homeassistant/homeassistant/helpers/config_validation.py", line 588, in verify
return cast(dict, schema(value))
File "/usr/local/lib/python3.11/site-packages/voluptuous/schema_builder.py", line 272, in __call__
return self._compiled([], data)
File "/usr/local/lib/python3.11/site-packages/voluptuous/schema_builder.py", line 595, in validate_dict
return base_validate(path, iteritems(data), out)
File "/usr/local/lib/python3.11/site-packages/voluptuous/schema_builder.py", line 433, in validate_mapping
raise er.MultipleInvalid(errors)
voluptuous.error.MultipleInvalid: expected a dictionary for dictionary value @ data['waste']
[17:33:30] INFO: Home Assistant Core finish process exit code 1
[17:33:30] INFO: Home Assistant Core service shutdown
s6-rc: info: service legacy-services: stopping
s6-rc: info: service legacy-services successfully stopped
s6-rc: info: service legacy-cont-init: stopping
s6-rc: info: service legacy-cont-init successfully stopped
s6-rc: info: service fix-attrs: stopping
s6-rc: info: service fix-attrs successfully stopped
s6-rc: info: service s6rc-oneshot-runner: stopping
s6-rc: info: service s6rc-oneshot-runner successfully stopped
