UPDATE: I made some headway on this. I parsed the output to Gemini and found the issue to be with SSL. I used to use DuckDNS but removed it. I edited the configuration.yaml to exclude the SSL info and it fired up. Still have a few issues but I can work through those.
I am migrating form VirtualBox to Proxmox using backup/restore but after several attempts I do not know what else to try. HAOS is the exact same version, OS, sup, docker between the 2 servers. I have tried restoring locally as well as cloud and even did a fresh backup and tried again. I ran a job info and it always shows the exact same thing. I noticed await_home_assistant_restart so restarted during a couple of attempts. The restart looks like it should be coming up but the GUI will not however it does ping (new IP). I assume the IP will change back to original after the restore but I don’t see that happen, I can ping the new IP but get “cant’ reach page”, “refused to connect” on Edge.
At the bottom is the OS log which shows errors early on
Here is restore job info:
# ha jobs info
ignore_conditions: []
jobs:
- child_jobs:
- child_jobs: []
created: "2025-10-15T13:29:56.696791+00:00"
done: true
errors: []
extra: null
progress: 100
reference: 4b9a6a05
stage: null
uuid: f5b28079d9c5498a831d58b603fe7ce5
- child_jobs:
- child_jobs: []
created: "2025-10-15T13:30:19.307724+00:00"
done: true
errors: []
extra: null
progress: 100
reference: core_configurator
stage: null
uuid: 2d973be3fc7e4fcb81cf024d01e5a890
- child_jobs: []
created: "2025-10-15T13:30:39.625024+00:00"
done: true
errors: []
extra: null
progress: 100
reference: core_matter_server
stage: null
uuid: 93b7fe2bad98427eb3e86ec035f4c245
- child_jobs: []
created: "2025-10-15T13:32:19.823520+00:00"
done: true
errors: []
extra: null
progress: 100
reference: 1d2e7f3c_ecowitt-proxy
stage: null
uuid: 69abd678b8e2459cb049a43dc1b13d05
- child_jobs: []
created: "2025-10-15T13:33:25.353636+00:00"
done: true
errors: []
extra: null
progress: 100
reference: core_ssh
stage: null
uuid: 7110a07597db4b8da846a18dc1ac6d4f
created: "2025-10-15T13:30:19.307637+00:00"
done: true
errors: []
extra: null
progress: 100
reference: 4b9a6a05
stage: null
uuid: 6c4bc29663aa48eebc2f9a7f18ad8d3c
- child_jobs: []
created: "2025-10-15T13:34:26.011270+00:00"
done: true
errors:
- message: No Home Assistant Core response, assuming a fatal startup error
stage: null
type: HomeAssistantStartupTimeout
extra: null
progress: 0
reference: null
stage: null
uuid: 865303f26acc489488f8a067dcb95d48
created: "2025-10-15T13:29:56.386144+00:00"
done: true
errors:
stage: await_home_assistant_restart
extra: null
progress: 0
reference: 4b9a6a05
uuid: 99f5ed84682241abb57187b5cf345665
After restart I see:
# ha jobs info
jobs:
- child_jobs: []
created: "2025-10-15T15:15:40.045714+00:00"
done: false
errors: []
extra: null
progress: 0
reference: null
stage: null
uuid: c17c5937d0384b56abd631b2b128708b
OS log
File "/usr/src/homeassistant/homeassistant/components/zeroconf/__init__.py", line 114, in async_get_async_zeroconf
return _async_get_instance(hass)
File "/usr/src/homeassistant/homeassistant/components/zeroconf/__init__.py", line 121, in _async_get_instance
zeroconf = HaZeroconf(**_async_get_zc_args(hass))
File "/usr/src/homeassistant/homeassistant/components/zeroconf/__init__.py", line 152, in _async_get_zc_args
adapters = network.async_get_loaded_adapters(hass)
File "/usr/src/homeassistant/homeassistant/components/network/__init__.py", line 55, in async_get_loaded_adapters
return async_get_loaded_network(hass).adapters
File "/usr/src/homeassistant/homeassistant/components/network/network.py", line 32, in async_get_loaded_network
return hass.data[DATA_NETWORK]
KeyError: 'network'
2025-10-15 09:34:03.972 ERROR (MainThread) [homeassistant.config_entries] Error setting up entry Home for met
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 751, in __async_setup_with_context
result = await component.async_setup_entry(hass, self)
File "/usr/src/homeassistant/homeassistant/components/met/__init__.py", line 42, in async_setup_entry
coordinator = MetDataUpdateCoordinator(hass, config_entry)
File "/usr/src/homeassistant/homeassistant/components/met/coordinator.py", line 101, in __init__
self.weather.set_coordinates()
File "/usr/src/homeassistant/homeassistant/components/met/coordinator.py", line 74, in set_coordinates
coordinates, async_get_clientsession(self.hass), api_url=URL
File "/usr/src/homeassistant/homeassistant/helpers/aiohttp_client.py", line 144, in async_get_clientsession
session = _async_create_clientsession(
hass,
...<3 lines>...
ssl_cipher=ssl_cipher,
File "/usr/src/homeassistant/homeassistant/helpers/aiohttp_client.py", line 203, in _async_create_clientsession
connector=_async_get_connector(hass, verify_ssl, family, ssl_cipher),
File "/usr/src/homeassistant/homeassistant/helpers/aiohttp_client.py", line 383, in _async_get_connector
resolver=_async_get_or_create_resolver(hass),
File "/usr/src/homeassistant/homeassistant/helpers/singleton.py", line 58, in wrapped
hass.data[data_key] = func(hass)
File "/usr/src/homeassistant/homeassistant/helpers/aiohttp_client.py", line 400, in _async_get_or_create_resolver
resolver = _async_make_resolver(hass)
File "/usr/src/homeassistant/homeassistant/helpers/aiohttp_client.py", line 411, in _async_make_resolver
return HassAsyncDNSResolver(async_zeroconf=zeroconf.async_get_async_zeroconf(hass))
KeyError: 'network'
2025-10-15 09:34:03.982 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of 'default_config'. Setup failed for dependencies: ['assist_pipeline', 'bluetooth', 'cloud', 'conversation', 'dhcp', 'energy', 'go2rtc', 'history', 'logbook', 'media_source', 'mobile_app', 'my', 'ssdp', 'stream', 'usb', 'webhook', 'zeroconf']
2025-10-15 09:34:03.982 ERROR (MainThread) [homeassistant.setup] Setup failed for 'default_config': Could not setup dependencies: assist_pipeline, bluetooth, cloud, conversation, dhcp, energy, go2rtc, history, logbook, media_source, mobile_app, my, ssdp, stream, usb, webhook, zeroconf
2025-10-15 09:34:06.003 WARNING (MainThread) [homeassistant.config_entries] Config entry '[email protected]' for tuya integration could not authenticate: Authentication failed. Please re-authenticate
2025-10-15 09:34:11.260 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of 'media_player'. Setup failed for dependencies: ['http']
2025-10-15 09:34:11.260 ERROR (MainThread) [homeassistant.setup] Setup failed for 'media_player': Could not setup dependencies: http
2025-10-15 09:34:11.279 WARNING (MainThread) [homeassistant.bootstrap] Detected that frontend did not load. Activating recovery mode
2025-10-15 09:34:11.694 ERROR (MainThread) [homeassistant.config] 2025-10-15 09:34:11.694 ERROR (MainThread) [homeassistant.config] Invalid config for 'http': not a file for dictionary value 'http->ssl_certificate', got '/ssl/fullchain.pem', please check the docs at https://www.home-assistant.io/integrations/http
Invalid config for 'http': not a file for dictionary value 'http->ssl_key', got '/ssl/privkey.pem', please check the docs at https://www.home-assistant.io/integrations/http
2025-10-15 09:34:11.694 ERROR (MainThread) [homeassistant.setup] 2025-10-15 09:34:11.694 ERROR (MainThread) [homeassistant.setup] Setup failed for 'http': Invalid config.
2025-10-15 09:34:11.694 ERROR (MainThread) [homeassistant.setup] 2025-10-15 09:34:11.694 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of 'diagnostics'. Setup failed for dependencies: ['http']
2025-10-15 09:34:11.694 ERROR (MainThread) [homeassistant.setup] 2025-10-15 09:34:11.694 ERROR (MainThread) [homeassistant.setup] Setup failed for 'diagnostics': Could not setup dependencies: http
2025-10-15 09:34:11.695 ERROR (MainThread) [homeassistant.setup] 2025-10-15 09:34:11.695 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of 'websocket_api'. Setup failed for dependencies: ['http']
2025-10-15 09:34:11.695 ERROR (MainThread) [homeassistant.setup] 2025-10-15 09:34:11.695 ERROR (MainThread) [homeassistant.setup] Setup failed for 'websocket_api': Could not setup dependencies: http
2025-10-15 09:34:11.695 ERROR (MainThread) [homeassistant.setup] 2025-10-15 09:34:11.695 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of 'file_upload'. Setup failed for dependencies: ['http']
2025-10-15 09:34:11.695 ERROR (MainThread) [homeassistant.setup] 2025-10-15 09:34:11.695 ERROR (MainThread) [homeassistant.setup] Setup failed for 'file_upload': Could not setup dependencies: http
2025-10-15 09:34:11.695 ERROR (MainThread) [homeassistant.setup] 2025-10-15 09:34:11.695 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of 'auth'. Setup failed for dependencies: ['http']
2025-10-15 09:34:11.695 ERROR (MainThread) [homeassistant.setup] 2025-10-15 09:34:11.695 ERROR (MainThread) [homeassistant.setup] Setup failed for 'auth': Could not setup dependencies: http
2025-10-15 09:34:11.695 ERROR (MainThread) [homeassistant.setup] 2025-10-15 09:34:11.695 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of 'config'. Setup failed for dependencies: ['http']
2025-10-15 09:34:11.695 ERROR (MainThread) [homeassistant.setup] 2025-10-15 09:34:11.695 ERROR (MainThread) [homeassistant.setup] Setup failed for 'config': Could not setup dependencies: http
2025-10-15 09:34:11.695 ERROR (MainThread) [homeassistant.setup] 2025-10-15 09:34:11.695 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of 'repairs'. Setup failed for dependencies: ['http']
2025-10-15 09:34:11.696 ERROR (MainThread) [homeassistant.setup] 2025-10-15 09:34:11.696 ERROR (MainThread) [homeassistant.setup] Setup failed for 'repairs': Could not setup dependencies: http
2025-10-15 09:34:11.696 ERROR (MainThread) [homeassistant.setup] 2025-10-15 09:34:11.696 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of 'api'. Setup failed for dependencies: ['http']
2025-10-15 09:34:11.696 ERROR (MainThread) [homeassistant.setup] 2025-10-15 09:34:11.696 ERROR (MainThread) [homeassistant.setup] Setup failed for 'api': Could not setup dependencies: http
2025-10-15 09:34:11.696 ERROR (MainThread) [homeassistant.setup] 2025-10-15 09:34:11.696 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of 'search'. Setup failed for dependencies: ['websocket_api']
2025-10-15 09:34:11.696 ERROR (MainThread) [homeassistant.setup] 2025-10-15 09:34:11.696 ERROR (MainThread) [homeassistant.setup] Setup failed for 'search': Could not setup dependencies: websocket_api
2025-10-15 09:34:11.696 ERROR (MainThread) [homeassistant.setup] 2025-10-15 09:34:11.696 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of 'onboarding'. Setup failed for dependencies: ['auth', 'http']
2025-10-15 09:34:11.696 ERROR (MainThread) [homeassistant.setup] 2025-10-15 09:34:11.696 ERROR (MainThread) [homeassistant.setup] Setup failed for 'onboarding': Could not setup dependencies: auth, http
2025-10-15 09:34:11.697 ERROR (MainThread) [homeassistant.setup] 2025-10-15 09:34:11.697 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of 'lovelace'. Setup failed for dependencies: ['onboarding']
2025-10-15 09:34:11.697 ERROR (MainThread) [homeassistant.setup] 2025-10-15 09:34:11.697 ERROR (MainThread) [homeassistant.setup] Setup failed for 'lovelace': Could not setup dependencies: onboarding
2025-10-15 09:34:11.697 ERROR (MainThread) [homeassistant.setup] 2025-10-15 09:34:11.697 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of 'frontend'. Setup failed for dependencies: ['api', 'auth', 'config', 'diagnostics', 'file_upload', 'http', 'lovelace', 'onboarding', 'repairs', 'search', 'websocket_api']
2025-10-15 09:34:11.697 ERROR (MainThread) [homeassistant.setup] 2025-10-15 09:34:11.697 ERROR (MainThread) [homeassistant.setup] Setup failed for 'frontend': Could not setup dependencies: api, auth, config, diagnostics, file_upload, http, lovelace, onboarding, repairs, search, websocket_api
2025-10-15 09:34:11.697 ERROR (MainThread) [homeassistant.setup] 2025-10-15 09:34:11.697 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of 'webhook'. Setup failed for dependencies: ['http']
2025-10-15 09:34:11.697 ERROR (MainThread) [homeassistant.setup] 2025-10-15 09:34:11.697 ERROR (MainThread) [homeassistant.setup] Setup failed for 'webhook': Could not setup dependencies: http
2025-10-15 09:34:11.698 ERROR (MainThread) [homeassistant.setup] 2025-10-15 09:34:11.698 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of 'cloud'. Setup failed for dependencies: ['auth', 'http', 'repairs', 'webhook']
2025-10-15 09:34:11.698 ERROR (MainThread) [homeassistant.setup] 2025-10-15 09:34:11.698 ERROR (MainThread) [homeassistant.setup] Setup failed for 'cloud': Could not setup dependencies: auth, http, repairs, webhook
2025-10-15 09:34:11.698 ERROR (MainThread) [homeassistant.setup] 2025-10-15 09:34:11.698 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of 'hassio'. Setup failed for dependencies: ['http', 'repairs']
2025-10-15 09:34:11.698 ERROR (MainThread) [homeassistant.setup] 2025-10-15 09:34:11.698 ERROR (MainThread) [homeassistant.setup] Setup failed for 'hassio': Could not setup dependencies: http, repairs
2025-10-15 09:34:11.698 ERROR (MainThread) [homeassistant.setup] 2025-10-15 09:34:11.698 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of 'recovery_mode'. Setup failed for dependencies: ['frontend', 'cloud']
2025-10-15 09:34:11.698 ERROR (MainThread) [homeassistant.setup] 2025-10-15 09:34:11.698 ERROR (MainThread) [homeassistant.setup] Setup failed for 'recovery_mode': Could not setup dependencies: frontend, cloud
