I’d like to control my audio amplifier from Home Assistant for on/off and volume up and down.
I have an ESP32-ETH01 controller connected via RJ45, equipped with a MAX3232 connector. The DB9 port is connected to my amplifier with a DB9 null modem cable (male/female).
I can’t get it to work. Absolutely nothing happens.
However, all the instructions worked when using the USB port directly between my Home Assistant PC and the amplifier.
I’ve tried other connectors, and each time I’ve also tested swapping the TX and RX ports, but nothing works.
Can anyone help me
ma carte max3232mon controlleur ESP32-ETH01?
esphome:
esp32:
board: esp32dev
framework:
type: arduino
# si on ne met pas la commande "power_pin: GPIO16"
# la carte ethernet n'est pas reconnue
ethernet:
type: LAN8720
mdc_pin: GPIO23
mdio_pin: GPIO18
clk_mode: GPIO0_IN
phy_addr: 1
power_pin: GPIO16
uart:
tx_pin: GPIO04
rx_pin: GPIO32
baud_rate: 4800
stop_bits: 1
data_bits: 8
parity: NONE
debug:
direction: BOTH
# Création des boutons de commande
# Ces commandes ont été testées en liaison serie directe sur mon PC HA
# avec l'instruction PRINTF (car la commande "echo -ne" ne fonctionnait pas)
button:
name: "Primare - Power ON"
on_press:
- uart.write: [0x02, 0x57, 0x0F, 0x02, 0x10, 0x03]
name: "Primare - Standby"
on_press:
- uart.write: [0x02, 0x57, 0x0F, 0x01, 0x10, 0x03]
name: "Primare - Mute"
on_press:
- uart.write: [0x02, 0x57, 0x0F, 0x31, 0x10, 0x03]
name: "Primare - Volume +"
on_press:
- uart.write: [0x02, 0x57, 0x0F, 0x10, 0x10, 0x10, 0x03]
name: "Primare - Volume -"
on_press:
- uart.write: [0x02, 0x57, 0x0F, 0x11, 0x10, 0x03]
name: "Primare - Entrée PLATIN"
on_press:
- uart.write: [0x02, 0x57, 0x0F, 0x3C, 0x10, 0x03]
name: "Primare - Entrée DAPHILE"
on_press:
- uart.write: [0x02, 0x57, 0x0F, 0x06, 0x10, 0x03]
# Service pour envoyer des commandes manuelles si besoin
api:
services:
- service: send_primare_command
variables:
payload: int[]
then:
- uart.write:
data: !lambda |-
std::vector<uint8_t> data;
for (auto val : payload) { data.push_back((uint8_t)val); }
return data;
ota:
- platform: esphome
logger:
level: DEBUG
baud_rate: 0
Perhaps my reasoning is flawed and my hardware configuration is unsuitable.
Do you have any ideas?
Thanks in advance.
