Unable to show mqtt devices from sofar2mqtt
Pretty new to HA and stuggling to grasp the concepts
my configuration.yaml is :
default_config:
# Load frontend themes from the themes folder
frontend:
  themes: !include_dir_merge_named themes
script: !include scripts.yaml
scene: !include scenes.yaml
#Energy_from_battery: !include sofar.yaml
#homematic: !include homematic.yaml
energy: !include sofar.yaml
light: !include lights.yaml
and sofar.yaml is :
#Sofar ME3000SP Sofar2mqtt sensors
#Updated to now include the new MQTT sensors required for 2022.12 release of Home Assistant onwards
  - platform: integration
    source: sensor.inverter_battery_discharge
    unit_prefix: k
    unit_time: h
    method: left
    source: sensor.inverter_battery_charge
    unit_prefix: k
    unit_time: h
    method: left
mqtt:
    - name: "inverter_running_state"
      state_topic: "sofar/state"
      value_template: >-
        {% if value_json.running_state == 0 %}
        {{ "0-Standby" }}
        {% elif value_json.running_state == 1 %}
        {{ "1-Check charge" }}
        {% elif value_json.running_state == 2 %}
        {{ "2-Charging" }}
        {% elif value_json.running_state == 3 %}
        {{ "3-Check discharge" }}
        {% elif value_json.running_state == 4 %}
        {{ "4-Discharging" }}
        {% elif value_json.running_state == 5 %}
        {{ "5-EPSState" }}
        {% elif value_json.running_state == 6 %}
        {{ "6-Fault" }}
        {% elif value_json.running_state == 7 %}
        {{ "7-Perminant Fault" }}
        {% else %}
        {{ "Undeterminated" }}
        {% endif %}
    - name: "grid_voltage"
      unit_of_measurement: "V"
      device_class: voltage
      state_class: measurement
      value_template: "{{ value_json.grid_voltage / 10}}"
    - name: "grid_current"
      unit_of_measurement: "A"
      device_class: current
      value_template: "{{ value_json.grid_current /100 }}"
yet, no device appears in my list.
What did i do wrong ?
Claude
