Unable to Start Home Assistant via LaunchDaemon on macOS (Permission Denied, BTM Policy)
Hello everyone,
I’m trying to run Home Assistant as a system service on macOS using a LaunchDaemon (homeAssistantAutoLaunch.plist). However, I keep encountering permission errors and BTM policy issues.
Setup Details:
macOS version: Sequoia 15.3
Home Assistant installed in: /Users/homeassistant/homeassistant/
Start script: /Users/homeassistant/homeassistant/start_homeassistant.sh
start_homeassistant.sh:
source /Users/homeassistant/homeassistant/bin/activate
exec hass --debug -v
LaunchDaemon location: /Library/LaunchDaemons/com.homeassistant.plist
Main issue: I log in with an administrator account and want to autolaunch the script under homeassistant user.
Errors Encountered:
  1. When starting via launchctl (as a daemon) :
    Service could not initialize: posix_spawn(/Users/homeassistant/homeassistant/start_homeassistant.sh), error 0xd - Permission denied
  2. When running manually as homeassistant :
    sudo -u homeassistant /Users/homeassistant/homeassistant/start_homeassistant.sh
    PermissionError: [Errno 13] Permission denied: ‘/Users/myuser/.homeassistant/home-assistant.log.fault’
  3. Previous error when plist was in LaunchAgents :
    Service could not initialize: Unable to verify trusted spawn(…), error 0xa1 - Service cannot be launched because of BTM policy
What I’ve Tried:
• Moved plist from LaunchAgents to LaunchDaemons.
• Checked permissions:
sudo chown -R homeassistant:staff /Users/homeassistant/homeassistant
sudo chmod -R 755 /Users/homeassistant/homeassistant
Questions:
  1. How can I fix the Permission denied error when running Home Assistant as homeassistant?
  2. How do I resolve the BTM policy issue when using launchctl?
  3. Is there a recommended way to properly set up Home Assistant as a system service on macOS when launching under a different user?
When I launch all command manually from termianl it works fine.
How to replace the command: sudo -u homeassistant -H -s in plist or in the script?
