Unable to start ZHA after Sonoff Flash
I have a Sonoff Dongle-P Zigbee coordinator and I just flashed the firmware with ZigStar TI CC2652P/P7 FW Flasher Addon from Home Assistant. But I now have an error when ZHA is trying to start up (error : Failed setup, will retry: Check the logs)… Since I’m quite new with HA, I don’t really know where to look for these logs. (Found them…)
I read that I had to do the pairing all over again, is that right ?
Also, I’m not sure the flash went well, how can I check that ?
Here are the logs of the flash :
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service banner: starting
Add-on: ZigStar TI CC2652P/P7 FW Flasher
ZigStar TI CC2652P/P7 firmware flasher add-on
Add-on version: 0.4.1
You are running the latest version of this add-on.
System: Home Assistant OS 15.0 (aarch64 / raspberrypi3-64)
Home Assistant Core: 2025.3.4
Home Assistant Supervisor: 2025.03.3
Please, share the above information when looking for help
or support in, e.g., GitHub, forums or the Discord chat.
s6-rc: info: service banner successfully started
s6-rc: info: service cc2652-flasher: starting
[15:55:06] INFO: Starting CC2652P flasher with Sonoff /dev/ttyUSB0
Setting filename to /root/firmware.hex
sonoff
Opening port /dev/ttyUSB0, baud 500000
Reading data from /root/firmware.hex
Your firmware looks like an Intel Hex file
Connecting to target...
pg_rev = 3, protocols = f, wafer_id = 0xbb41
CC135x PG2.1 (7x7mm): 352KB Flash, 20KB SRAM, CCFG.BL_CONFIG at 0x00057FD8
Primary IEEE Address: 00:12:4B:00:2C:3A:AD:67
Performing mass erase
Erasing all main bank flash sectors
Erase done
Writing 360448 bytes starting at address 0x00000000
Write 248 bytes at 0x00000000 Write 248 bytes at 0x000000F8 Write 248 bytes at 0x000001F0 Write 248 bytes at 0x000002E8 Write 248 bytes at 0x000003E0 Write 248 bytes at 0x000004D8 Write 248 bytes at 0x000005D0 Write 248 bytes at 0x000006C8 Write 248 bytes at 0x000007C0 Write 248 bytes at 0x000008B8 Write 248 bytes at 0x000009B0 Write 248 bytes at 0x00000AA8 Write 248 bytes at 0x00000BA0 Write 248 bytes at 0x00000C98 Write 248 bytes at 0x00000D90 Write 248 bytes at 0x00000E88 Write 248 bytes at 0x00000F80 Write 248 bytes at 0x00001078 Write 248 bytes at 0x00001170 Write 248 bytes at 0x00001268 Write 248 bytes at 0x00001360 Write 248 bytes at 0x00001458 Write 248 bytes at 0x00001550 Write 248 bytes at 0x00001648 Write 248 bytes at 0x00001740 Write 248 bytes at 0x00001838 Write 248 bytes at 0x00001930 Write 248 bytes at 0x00001A28 Write 248 bytes at 0x00001B20 Write 248 bytes at 0x00001C18 Write 248 bytes at 0x00001D10 Write 248 bytes at 0x00001E08 Write 248 bytes at 0x00001F00 Write 248 bytes at 0x00001FF8 Write 248 bytes at 0x000020F0 Write 248 bytes at 0x000021E8 Write 248 bytes at 0x000022E0 Write 248 bytes at 0x000023D8 Write 248 bytes at 0x000024D0 Write 248 bytes at 0x000025C8 Write 248 bytes at 0x000026C0 Write 248 bytes at 0x000027B8 Write 248 bytes at 0x000028B0 Write 248 bytes at 0x000029A8 Write 248 bytes at 0x00002AA0 Write 248 bytes at 0x00002B98 Write 248 bytes at 0x00002C90 Write 248 bytes at 0x00002D88 Write 248 bytes at 0x00002E80 Write 248 bytes at 0x00002F78 Write 248 bytes at 0x00003070 Write 248 bytes at 0x00003168 Write 248 bytes at 0x00003260 Write 248 bytes at 0x00003358 Write 248 bytes at 0x00003450 Write 248 bytes at 0x00003548 Write 248 bytes at 0x00003640 Write 248 bytes at 0x00003738 Write 248 bytes at 0x00003830 Write 248 bytes at 0x00003928 Write 248 bytes at 0x00003A20 Write 248 bytes at 0x00003B18 Write 248 bytes at 0x00003C10 Write 248 bytes at 0x00003D08 Write 248 bytes at 0x00003E00 Write 248 bytes at 0x00003EF8 Write 248 bytes at 0x00003FF0 Write 248 bytes at 0x000040E8 Write 248 bytes at 0x000041E0 Write 248 bytes at 0x000042D8 Write 248 bytes at 0x000043D0 Write 248 bytes at 0x000044C8 Write 248 bytes at 0x000045C0 Write 248 bytes at 0x000046B8 Write 248 bytes at 0x000047B0 Write 248 bytes at 0x000048A8 Write 248 bytes at 0x000049A0 Write 248 bytes at 0x00004A98 Write 248 bytes at 0x00004B90 Write 248 bytes at 0x00004C88 Write 248 bytes at 0x00004D80 Write 248 bytes at 0x00004E78 Write 248 bytes at 0x00004F70 Write 248 bytes at 0x00005068 Write 248 bytes at 0x00005160 Write 248 bytes at 0x00005258 Write 248 bytes at 0x00005350 Write 248 bytes at 0x00005448 Write 248 bytes at 0x00005540 Write 248 bytes at 0x00005638 Write 248 bytes at 0x00005730 Write 248 bytes at 0x00005828 Write 248 bytes at 0x00005920 Write 248 bytes at 0x00005A18 Write 248 bytes at 0x00005B10 Write 248 bytes at 0x00005C08 Write 248 bytes at 0x00005D00 Write 248 bytes at 0x00005DF8 Write 248 bytes at 0x00005EF0 Write 248 bytes at 0x00005FE8 Write 248 bytes at 0x000060E0 Write 248 bytes at 0x000061D8 Write 248 bytes at 0x000062D0 Write 248 bytes at 0x000063C8 Write 248 bytes at 0x000064C0 Write 248 bytes at 0x000065B8 Write 248 bytes at 0x000066B0 Write 248 bytes at 0x000067A8 Write 248 bytes at 0x000068A0 Write 248 bytes at 0x00006998 Write 248 bytes at 0x00006A90 Write 248 bytes at 0x00006B88 Write 248 bytes at 0x00006C80 Write 248 bytes at 0x00006D78 Write 248 bytes at 0x00006E70 Write 248 bytes at 0x00006F68 Write 248 bytes at 0x00007060 Write 248 bytes at 0x00007158 Write 248 bytes at 0x00007250 Write 248 bytes at 0x00007348 Write 248 bytes at 0x00007440 Write 248 bytes at 0x00007538 Write 248 bytes at 0x00007630 Write 248 bytes at 0x00007728 Write 248 bytes at 0x00007820 Write 248 bytes at 0x00007918 Write 248 bytes at 0x00007A10 Write 248 bytes at 0x00007B08 Write 248 bytes at 0x00007C00 Write 248 bytes at 0x00007CF8 Write 248 bytes at 0x00007DF0 Write 248 bytes at 0x00007EE8 Write 248 bytes at 0x00007FE0 Write 248 bytes at 0x000080D8 Write 248 bytes at 0x000081D0 Write 248 bytes at 0x000082C8 Write 248 bytes at 0x000083C0 Write 248 bytes at 0x000084B8 Write 248 bytes at 0x000085B0 Write 248 bytes at 0x000086A8 Write 248 bytes at 0x000087A0 Write 248 bytes at 0x00008898 Write 248 bytes at 0x00008990 Write 248 bytes at 0x00008A88 Write 248 bytes at 0x00008B80 Write 248 bytes at 0x00008C78 Write 248 bytes at 0x00008D70 Write 248 bytes at 0x00008E68 Write 248 bytes at 0x00008F60 Write 248 bytes at 0x00009058 Write 248 bytes at 0x00009150 Write 248 bytes at 0x00009248 Write 248 bytes at 0x00009340 Write 248 bytes at 0x00009438 Write 248 bytes at 0x00009530 Write 248 bytes at 0x00009628 Write 248 bytes at 0x00009720 Write 248 bytes at 0x00009818 Write 248 bytes at 0x00009910 Write 248 bytes at 0x00009A08 Write 248 bytes at 0x00009B00 Write 248 bytes at 0x00009BF8 Write 248 bytes at 0x00009CF0 Write 248 bytes at 0x00009DE8 Write 248 bytes at 0x00009EE0 Write 248 bytes at 0x00009FD8 Write 248 bytes at 0x0000A0D0 Write 248 bytes at 0x0000A1C8 Write 248 bytes at 0x0000A2C0 Write 248 bytes at 0x0000A3B8 Write 248 bytes at 0x0000A4B0 Write 248 bytes at 0x0000A5A8 Write 248 bytes at 0x0000A6A0 Write 248 bytes at 0x0000A798 Write 248 bytes at 0x0000A890 Write 248 bytes at 0x0000A988 Write 248 bytes at 0x0000AA80 Write 248 bytes at 0x0000AB78 Write 248 bytes at 0x0000AC70 Write 248 bytes at 0x0000AD68 Write 248 bytes at 0x0000AE60 Write 248 bytes at 0x0000AF58 Write 248 bytes at 0x0000B050 Write 248 bytes at 0x0000B148 Write 248 bytes at 0x0000B240 Write 248 bytes at 0x0000B338 Write 248 bytes at 0x0000B430 Write 248 bytes at 0x0000B528 Write 248 bytes at 0x0000B620 Write 248 bytes at 0x0000B718 Write 248 bytes at 0x0000B810 Write 248 bytes at 0x0000B908 Write 248 bytes at 0x0000BA00 Write 248 bytes at 0x0000BAF8 Write 248 bytes at 0x0000BBF0 Write 248 bytes at 0x0000BCE8 Write 248 bytes at 0x0000BDE0 Write 248 bytes at 0x0000BED8 Write 248 bytes at 0x0000BFD0 Write 248 bytes at 0x0000C0C8 Write 248 bytes at 0x0000C1C0 Write 248 bytes at 0x0000C2B8 Write 248 bytes at 0x0000C3B0 Write 248 bytes at 0x0000C4A8 Write 248 bytes at 0x0000C5A0 Write 248 bytes at 0x0000C698 Write 248 bytes at 0x0000C790 Write 248 bytes at 0x0000C888 Write 248 bytes at 0x0000C980 Write 248 bytes at 0x0000CA78 Write 248 bytes at 0x0000CB70 Write 248 bytes at 0x0000CC68 Write 248 bytes at 0x0000CD60 Write 248 bytes at 0x0000CE58 Write 248 bytes at 0x0000CF50 Write 248 bytes at 0x0000D048 Write 248 bytes at 0x0000D140 Write 248 bytes at 0x0000D238 Write 248 bytes at 0x0000D330 Write 248 bytes at 0x0000D428 Write 248 bytes at 0x0000D520 Write 248 bytes at 0x0000D618 Write 248 bytes at 0x0000D710 Write 248 bytes at 0x0000D808 Write 248 bytes at 0x0000D900 Write 248 bytes at 0x0000D9F8 Write 248 bytes at 0x0000DAF0 Write 248 bytes at 0x0000DBE8 Write 248 bytes at 0x0000DCE0 Write 248 bytes at 0x0000DDD8 Write 248 bytes at 0x0000DED0 Write 248 bytes at 0x0000DFC8 Write 248 bytes at 0x0000E0C0 Write 248 bytes at 0x0000E1B8 Write 248 bytes at 0x0000E2B0 Write 248 bytes at 0x0000E3A8 Write 248 bytes at 0x0000E4A0 Write 248 bytes at 0x0000E598 Write 248 bytes at 0x0000E690 Write 248 bytes at 0x0000E788 Write 248 bytes at 0x0000E880 Write 248 bytes at 0x0000E978 Write 248 bytes at 0x0000EA70 Write 248 bytes at 0x0000EB68 Write 248 bytes at 0x0000EC60 Write 248 bytes at 0x0000ED58 Write 248 bytes at 0x0000EE50 Write 248 bytes at 0x0000EF48 Write 248 bytes at 0x0000F040 Write 248 bytes at 0x0000F138 Write 248 bytes at 0x0000F230 Write 248 bytes at 0x0000F328 Write 248 bytes at 0x0000F420 Write 248 bytes at 0x0000F518 Write 248 bytes at 0x0000F610 Write 248 bytes at 0x0000F708 Write 248 bytes at 0x0000F800 Write 248 bytes at 0x0000F8F8 Write 248 bytes at 0x0000F9F0 Write 248 bytes at 0x0000FAE8 Write 248 bytes at 0x0000FBE0 Write 248 bytes at 0x0000FCD8 Write 248 bytes at 0x0000FDD0 Write 248 bytes at 0x0000FEC8 Write 248 bytes at 0x0000FFC0 Write 248 bytes at 0x000100B8 Write 248 bytes at 0x000101B0 Write 248 bytes at 0x000102A8 Write 248 bytes at 0x000103A0 Write 248 bytes at 0x00010498 Write 248 bytes at 0x00010590 Write 248 bytes at 0x00010688 Write 248 bytes at 0x00010780 Write 248 bytes at 0x00010878 Write 248 bytes at 0x00010970 Write 248 bytes at 0x00010A68 Write 248 bytes at 0x00010B60 Write 248 bytes at 0x00010C58 Write 248 bytes at 0x00010D50 Write 248 bytes at 0x00010E48 Write 248 bytes at 0x00010F40 Write 248 bytes at 0x00011038 Write 248 bytes at 0x00011130 Write 248 bytes at 0x00011228 Write 248 bytes at 0x00011320 Write 248 bytes at 0x00011418 Write 248 bytes at 0x00011510 Write 248 bytes at 0x00011608 Write 248 bytes at 0x00011700 Write 248 bytes at 0x000117F8 Write 248 bytes at 0x000118F0 Write 248 bytes at 0x000119E8 Write 248 bytes at 0x00011AE0 Write 248 bytes at 0x00011BD8 Write 248 bytes at 0x00011CD0 Write 248 bytes at 0x00011DC8 Write 248 bytes at 0x00011EC0 Write 248 bytes at 0x00011FB8 Write 248 bytes at 0x000120B0 Write 248 bytes at 0x000121A8 Write 248 bytes at 0x000122A0 Write 248 bytes at 0x00012398 Write 248 bytes at 0x00012490 Write 248 bytes at 0x00012588 Write 248 bytes at 0x00012680 Write 248 bytes at 0x00012778 Write 248 bytes at 0x00012870 Write 248 bytes at 0x00012968 Write 248 bytes at 0x00012A60 Write 248 bytes at 0x00012B58 Write 248 bytes at 0x00012C50 Write 248 bytes at 0x00012D48 Write 248 bytes at 0x00012E40 Write 248 bytes at 0x00012F38 Write 248 bytes at 0x00013030 Write 248 bytes at 0x00013128 Write 248 bytes at 0x00013220 Write 248 bytes at 0x00013318 Write 248 bytes at 0x00013410 Write 248 bytes at 0x00013508 Write 248 bytes at 0x00013600 Write 248 bytes at 0x000136F8 Write 248 bytes at 0x000137F0 Write 248 bytes at 0x000138E8 Write 248 bytes at 0x000139E0 Write 248 bytes at 0x00013AD8 Write 248 bytes at 0x00013BD0 Write 248 bytes at 0x00013CC8 Write 248 bytes at 0x00013DC0 Write 248 bytes at 0x00013EB8 Write 248 bytes at 0x00013FB0 Write 248 bytes at 0x000140A8 Write 248 bytes at 0x000141A0 Write 248 bytes at 0x00014298 Write 248 bytes at 0x00014390 Write 248 bytes at 0x00014488 Write 248 bytes at 0x00014580 Write 248 bytes at 0x00014678 Write 248 bytes at 0x00014770 Write 248 bytes at 0x00014868 Write 248 bytes at 0x00014960 Write 248 bytes at 0x00014A58 Write 248 bytes at 0x00014B50 Write 248 bytes at 0x00014C48 Write 248 bytes at 0x00014D40 Write 248 bytes at 0x00014E38 Write 248 bytes at 0x00014F30 Write 248 bytes at 0x00015028 Write 248 bytes at 0x00015120 Write 248 bytes at 0x00015218 Write 248 bytes at 0x00015310 Write 248 bytes at 0x00015408 Write 248 bytes at 0x00015500 Write 248 bytes at 0x000155F8 Write 248 bytes at 0x000156F0 Write 248 bytes at 0x000157E8 Write 248 bytes at 0x000158E0 Write 248 bytes at 0x000159D8 Write 248 bytes at 0x00015AD0 Write 248 bytes at 0x00015BC8 Write 248 bytes at 0x00015CC0 Write 248 bytes at 0x00015DB8 Write 248 bytes at 0x00015EB0 Write 248 bytes at 0x00015FA8 Write 248 bytes at 0x000160A0 Write 248 bytes at 0x00016198 Write 248 bytes at 0x00016290 Write 248 bytes at 0x00016388 Write 248 bytes at 0x00016480 Write 248 bytes at 0x00016578 Write 248 bytes at 0x00016670 Write 248 bytes at 0x00016768 Write 248 bytes at 0x00016860 Write 248 bytes at 0x00016958 Write 248 bytes at 0x00016A50 Write 248 bytes at 0x00016B48 Write 248 bytes at 0x00016C40 Write 248 bytes at 0x00016D38 Write 248 bytes at 0x00016E30 Write 248 bytes at 0x00016F28 Write 248 bytes at 0x00017020 Write 248 bytes at 0x00017118 Write 248 bytes at 0x00017210 Write 248 bytes at 0x00017308 Write 248 bytes at 0x00017400 Write 248 bytes at 0x000174F8 Write 248 bytes at 0x000175F0 Write 248 bytes at 0x000176E8 Write 248 bytes at 0x000177E0 Write 248 bytes at 0x000178D8 Write 248 bytes at 0x000179D0 Write 248 bytes at 0x00017AC8 Write 248 bytes at 0x00017BC0 Write 248 bytes at 0x00017CB8 Write 248 bytes at 0x00017DB0 Write 248 bytes at 0x00017EA8 Write 248 bytes at 0x00017FA0 Write 248 bytes at 0x00018098 Write 248 bytes at 0x00018190 Write 248 bytes at 0x00018288 Write 248 bytes at 0x00018380 Write 248 bytes at 0x00018478 Write 248 bytes at 0x00018570 Write 248 bytes at 0x00018668 Write 248 bytes at 0x00018760 Write 248 bytes at 0x00018858 Write 248 bytes at 0x00018950 Write 248 bytes at 0x00018A48 Write 248 bytes at 0x00018B40 Write 248 bytes at 0x00018C38 Write 248 bytes at 0x00018D30 Write 248 bytes at 0x00018E28 Write 248 bytes at 0x00018F20 Write 248 bytes at 0x00019018 Write 248 bytes at 0x00019110 Write 248 bytes at 0x00019208 Write 248 bytes at 0x00019300 Write 248 bytes at 0x000193F8 Write 248 bytes at 0x000194F0 Write 248 bytes at 0x000195E8 Write 248 bytes at 0x000196E0 Write 248 bytes at 0x000197D8 Write 248 bytes at 0x000198D0 Write 248 bytes at 0x000199C8 Write 248 bytes at 0x00019AC0 Write 248 bytes at 0x00019BB8 Write 248 bytes at 0x00019CB0 Write 248 bytes at 0x00019DA8 Write 248 bytes at 0x00019EA0 Write 248 bytes at 0x00019F98 Write 248 bytes at 0x0001A090 Write 248 bytes at 0x0001A188 Write 248 bytes at 0x0001A280 Write 248 bytes at 0x0001A378 Write 248 bytes at 0x0001A470 Write 248 bytes at 0x0001A568 Write 248 bytes at 0x0001A660 Write 248 bytes at 0x0001A758 Write 248 bytes at 0x0001A850 Write 248 bytes at 0x0001A948 Write 248 bytes at 0x0001AA40 Write 248 bytes at 0x0001AB38 Write 248 bytes at 0x0001AC30 Write 248 bytes at 0x0001AD28 Write 248 bytes at 0x0001AE20 Write 248 bytes at 0x0001AF18 Write 248 bytes at 0x0001B010 Write 248 bytes at 0x0001B108 Write 248 bytes at 0x0001B200 Write 248 bytes at 0x0001B2F8 Write 248 bytes at 0x0001B3F0 Write 248 bytes at 0x0001B4E8 Write 248 bytes at 0x0001B5E0 Write 248 bytes at 0x0001B6D8 Write 248 bytes at 0x0001B7D0 Write 248 bytes at 0x0001B8C8 Write 248 bytes at 0x0001B9C0 Write 248 bytes at 0x0001BAB8 Write 248 bytes at 0x0001BBB0 Write 248 bytes at 0x0001BCA8 Write 248 bytes at 0x0001BDA0 Write 248 bytes at 0x0001BE98 Write 248 bytes at 0x0001BF90 Write 248 bytes at 0x0001C088 Write 248 bytes at 0x0001C180 Write 248 bytes at 0x0001C278 Write 248 bytes at 0x0001C370 Write 248 bytes at 0x0001C468 Write 248 bytes at 0x0001C560 Write 248 bytes at 0x0001C658 Write 248 bytes at 0x0001C750 Write 248 bytes at 0x0001C848 Write 248 bytes at 0x0001C940 Write 248 bytes at 0x0001CA38 Write 248 bytes at 0x0001CB30 Write 248 bytes at 0x0001CC28 Write 248 bytes at 0x0001CD20 Write 248 bytes at 0x0001CE18 Write 248 bytes at 0x0001CF10 Write 248 bytes at 0x0001D008 Write 248 bytes at 0x0001D100 Write 248 bytes at 0x0001D1F8 Write 248 bytes at 0x0001D2F0 Write 248 bytes at 0x0001D3E8 Write 248 bytes at 0x0001D4E0 Write 248 bytes at 0x0001D5D8 Write 248 bytes at 0x0001D6D0 Write 248 bytes at 0x0001D7C8 Write 248 bytes at 0x0001D8C0 Write 248 bytes at 0x0001D9B8 Write 248 bytes at 0x0001DAB0 Write 248 bytes at 0x0001DBA8 Write 248 bytes at 0x0001DCA0 Write 248 bytes at 0x0001DD98 Write 248 bytes at 0x0001DE90 Write 248 bytes at 0x0001DF88 Write 248 bytes at 0x0001E080 Write 248 bytes at 0x0001E178 Write 248 bytes at 0x0001E270 Write 248 bytes at 0x0001E368 Write 248 bytes at 0x0001E460 Write 248 bytes at 0x0001E558 Write 248 bytes at 0x0001E650 Write 248 bytes at 0x0001E748 Write 248 bytes at 0x0001E840 Write 248 bytes at 0x0001E938 Write 248 bytes at 0x0001EA30 Write 248 bytes at 0x0001EB28 Write 248 bytes at 0x0001EC20 Write 248 bytes at 0x0001ED18 Write 248 bytes at 0x0001EE10 Write 248 bytes at 0x0001EF08 Write 248 bytes at 0x0001F000 Write 248 bytes at 0x0001F0F8 Write 248 bytes at 0x0001F1F0 Write 248 bytes at 0x0001F2E8 Write 248 bytes at 0x0001F3E0 Write 248 bytes at 0x0001F4D8 Write 248 bytes at 0x0001F5D0 Write 248 bytes at 0x0001F6C8 Write 248 bytes at 0x0001F7C0 Write 248 bytes at 0x0001F8B8 Write 248 bytes at 0x0001F9B0 Write 248 bytes at 0x0001FAA8 Write 248 bytes at 0x0001FBA0 Write 248 bytes at 0x0001FC98 Write 248 bytes at 0x0001FD90 Write 248 bytes at 0x0001FE88 Write 248 bytes
at 0x0001FF80 Write 248 bytes at 0x00020078 Write 248 bytes at 0x00020170 Write 248 bytes at 0x00020268 Write 248 bytes at 0x00020360 Write 248 bytes at 0x00020458 Write 248 bytes at 0x00020550 Write 248 bytes at 0x00020648 Write 248 bytes at 0x00020740 Write 248 bytes at 0x00020838 Write 248 bytes at 0x00020930 Write 248 bytes at 0x00020A28 Write 248 bytes at 0x00020B20 Write 248 bytes at 0x00020C18 Write 248 bytes at 0x00020D10 Write 248 bytes at 0x00020E08 Write 248 bytes at 0x00020F00 Write 248 bytes at 0x00020FF8 Write 248 bytes at 0x000210F0 Write 248 bytes at 0x000211E8 Write 248 bytes at 0x000212E0 Write 248 bytes at 0x000213D8 Write 248 bytes at 0x000214D0 Write 248 bytes at 0x000215C8 Write 248 bytes at 0x000216C0 Write 248 bytes at 0x000217B8 Write 248 bytes at 0x000218B0 Write 248 bytes at 0x000219A8 Write 248 bytes at 0x00021AA0 Write 248 bytes at 0x00021B98 Write 248 bytes at 0x00021C90 Write 248 bytes at 0x00021D88 Write 248 bytes at 0x00021E80 Write 248 bytes at 0x00021F78 Write 248 bytes at 0x00022070 Write 248 bytes at 0x00022168 Write 248 bytes at 0x00022260 Write 248 bytes at 0x00022358 Write 248 bytes at 0x00022450 Write 248 bytes at 0x00022548 Write 248 bytes at 0x00022640 Write 248 bytes at 0x00022738 Write 248 bytes at 0x00022830 Write 248 bytes at 0x00022928 Write 248 bytes at 0x00022A20 Write 248 bytes at 0x00022B18 Write 248 bytes at 0x00022C10 Write 248 bytes at 0x00022D08 Write 248 bytes at 0x00022E00 Write 248 bytes at 0x00022EF8 Write 248 bytes at 0x00022FF0 Write 248 bytes at 0x000230E8 Write 248 bytes at 0x000231E0 Write 248 bytes at 0x000232D8 Write 248 bytes at 0x000233D0 Write 248 bytes at 0x000234C8 Write 248 bytes at 0x000235C0 Write 248 bytes at 0x000236B8 Write 248 bytes at 0x000237B0 Write 248 bytes at 0x000238A8 Write 248 bytes at 0x000239A0 Write 248 bytes at 0x00023A98 Write 248 bytes at 0x00023B90 Write 248 bytes at 0x00023C88 Write 248 bytes at 0x00023D80 Write 248 bytes at 0x00023E78 Write 248 bytes at 0x00023F70 Write 248 bytes at 0x00024068 Write 248 bytes at 0x00024160 Write 248 bytes at 0x00024258 Write 248 bytes at 0x00024350 Write 248 bytes at 0x00024448 Write 248 bytes at 0x00024540 Write 248 bytes at 0x00024638 Write 248 bytes at 0x00024730 Write 248 bytes at 0x00024828 Write 248 bytes at 0x00024920 Write 248 bytes at 0x00024A18 Write 248 bytes at 0x00024B10 Write 248 bytes at 0x00024C08 Write 248 bytes at 0x00024D00 Write 248 bytes at 0x00024DF8 Write 248 bytes at 0x00024EF0 Write 248 bytes at 0x00024FE8 Write 248 bytes at 0x000250E0 Write 248 bytes at 0x000251D8 Write 248 bytes at 0x000252D0 Write 248 bytes at 0x000253C8 Write 248 bytes at 0x000254C0 Write 248 bytes at 0x000255B8 Write 248 bytes at 0x000256B0 Write 248 bytes at 0x000257A8 Write 248 bytes at 0x000258A0 Write 248 bytes at 0x00025998 Write 248 bytes at 0x00025A90 Write 248 bytes at 0x00025B88 Write 248 bytes at 0x00025C80 Write 248 bytes at 0x00025D78 Write 248 bytes at 0x00025E70 Write 248 bytes at 0x00025F68 Write 248 bytes at 0x00026060 Write 248 bytes at 0x00026158 Write 248 bytes at 0x00026250 Write 248 bytes at 0x00026348 Write 248 bytes at 0x00026440 Write 248 bytes at 0x00026538 Write 248 bytes at 0x00026630 Write 248 bytes at 0x00026728 Write 248 bytes at 0x00026820 Write 248 bytes at 0x00026918 Write 248 bytes at 0x00026A10 Write 248 bytes at 0x00026B08 Write 248 bytes at 0x00026C00 Write 248 bytes at 0x00026CF8 Write 248 bytes at 0x00026DF0 Write 248 bytes at 0x00026EE8 Write 248 bytes at 0x00026FE0 Write 248 bytes at 0x000270D8 Write 248 bytes at 0x000271D0 Write 248 bytes at 0x000272C8 Write 248 bytes at 0x000273C0 Write 248 bytes at 0x000274B8 Write 248 bytes at 0x000275B0 Write 248 bytes at 0x000276A8 Write 248 bytes at 0x000277A0 Write 248 bytes at 0x00027898 Write 248 bytes at 0x00027990 Write 248 bytes at 0x00027A88 Write 248 bytes at 0x00027B80 Write 248 bytes at 0x00027C78 Write 248 bytes at 0x00027D70 Write 248 bytes at 0x00027E68 Write 248 bytes at 0x00027F60 Write 248 bytes at 0x00028058 Write 248 bytes at 0x00028150 Write 248 bytes at 0x00028248 Write 248 bytes at 0x00028340 Write 248 bytes at 0x00028438 Write 248 bytes at 0x00028530 Write 248 bytes at 0x00028628 Write 248 bytes at 0x00028720 Write 248 bytes at 0x00028818 Write 248 bytes at 0x00028910 Write 248 bytes at 0x00028A08 Write 248 bytes at 0x00028B00 Write 248 bytes at 0x00028BF8 Write 248 bytes at 0x00028CF0 Write 248 bytes at 0x00028DE8 Write 248 bytes at 0x00028EE0 Write 248 bytes at 0x00028FD8 Write 248 bytes at 0x000290D0 Write 248 bytes at 0x000291C8 Write 248 bytes at 0x000292C0 Write 248 bytes at 0x000293B8 Write 248 bytes at 0x000294B0 Write 248 bytes at 0x000295A8 Write 248 bytes at 0x000296A0 Write 248 bytes at 0x00029798 Write 248 bytes at 0x00029890 Write 248 bytes at 0x00029988 Write 248 bytes at 0x00029A80 Write 248 bytes at 0x00029B78 ERROR: Timeout waiting for ACK/NACK after 'Get Status (0x23)'
[15:55:20] INFO: cc2652-flasher-up script exited with code 1
s6-rc: warning: unable to start service cc2652-flasher: command exited 1
/run/s6/basedir/scripts/rc.init: warning: s6-rc failed to properly bring all the services up! Check your logs (in /run/uncaught-logs/current if you have in-container logging) for more information.
/run/s6/basedir/scripts/rc.init: fatal: stopping the container.
s6-rc: info: service banner: stopping
s6-rc: info: service banner successfully stopped
s6-rc: info: service legacy-cont-init: stopping
s6-rc: info: service legacy-cont-init successfully stopped
s6-rc: info: service fix-attrs: stopping
s6-rc: info: service fix-attrs successfully stopped
s6-rc: info: service s6rc-oneshot-runner: stopping
s6-rc: info: service s6rc-oneshot-runner successfully stopped
Here is HA core logs :
2025-03-31 20:27:12.966 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event state_reported[L]: entity_id=binary_sensor.rpi_power_status, old_last_reported=2025-03-31T20:26:42.960116+02:00, new_state=<state binary_sensor.rpi_power_status=off; device_class=problem, icon=mdi:raspberry-pi, friendly_name=RPi Power status @ 2025-03-31T19:22:42.819720+02:00>>
2025-03-31 20:27:13.279 DEBUG (MainThread) [zigpy.backups] Adding a new backup NetworkBackup(version=1, backup_time=datetime.datetime(2025, 3, 30, 11, 42, 42, 654723, tzinfo=datetime.timezone.utc), network_info=NetworkInfo(extended_pan_id=03:16:7a:31:70:8a:13:4f, pan_id=0x76D5, nwk_update_id=0, nwk_manager_id=0x0000, channel=25, channel_mask=<Channels.CHANNEL_25: 33554432>, security_level=5, network_key=Key(key=80:59:ad:41:33:ba:e9:22:17:a0:69:d0:fc:db:9b:dc, tx_counter=1409384, rx_counter=0, seq=0, partner_ieee=00:12:4b:00:2c:3a:ad:67), tc_link_key=Key(key=5a:69:67:42:65:65:41:6c:6c:69:61:6e:63:65:30:39, tx_counter=0, rx_counter=0, seq=0, partner_ieee=00:12:4b:00:2c:3a:ad:67), key_table=[], children=[], nwk_addresses={}, stack_specific={'zstack': {'tclk_seed': 'fc49f090260172fd65c19fdf6b42eea7'}}, metadata={'zstack': {'TransportRev': 2, 'ProductId': 1, 'MajorRel': 2, 'MinorRel': 7, 'MaintRel': 1, 'CodeRevision': 20210708, 'BootloaderBuildType': 0, 'BootloaderRevision': None}}, source='[email protected]'), node_info=NodeInfo(nwk=0x0000, ieee=00:12:4b:00:2c:3a:ad:67, logical_type=<LogicalType.Coordinator: 0>, model='CC2652', manufacturer='Texas Instruments', version='Z-Stack 20210708'))
2025-03-31 20:27:13.281 DEBUG (MainThread) [zigpy.serial] Opening a serial connection to '/dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_ea1283213bb6ed118cf4d40ea8669f5d-if00-port0' (baudrate=115200, xonxoff=False, rtscts=False)
2025-03-31 20:27:13.294 DEBUG (MainThread) [zigpy.serial] Connection made: SerialTransport(<_UnixSelectorEventLoop running=True closed=False debug=False>, <ZnpMtProtocol connected to '/dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_ea1283213bb6ed118cf4d40ea8669f5d-if00-port0' (api: <zigpy_znp.api.ZNP object at 0x7f72a33cf0>)>, Serial<id=0x7f729a8130, open=True>(port='/dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_ea1283213bb6ed118cf4d40ea8669f5d-if00-port0', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=0, xonxoff=False, rtscts=False, dsrdtr=False))
2025-03-31 20:27:13.298 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event state_reported[L]: entity_id=sun.sun, old_last_reported=2025-03-31T20:26:58.296953+02:00, new_state=<state sun.sun=below_horizon; next_dawn=2025-04-01T04:44:07.477141+00:00, next_dusk=2025-03-31T18:46:01.938922+00:00, next_midnight=2025-03-31T23:45:21+00:00, next_noon=2025-04-01T11:45:29+00:00, next_rising=2025-04-01T05:17:50.511384+00:00, next_setting=2025-04-01T18:13:50.632626+00:00, elevation=-2.55, azimuth=280.31, rising=False, friendly_name=Sun @ 2025-03-31T20:16:14.498452+02:00>>
2025-03-31 20:27:13.298 DEBUG (MainThread) [zigpy_znp.api] Toggling RTS/DTR pins to skip bootloader or reset chip
2025-03-31 20:27:13.299 DEBUG (MainThread) [zigpy_znp.uart] Setting serial pin states: DTR=False, RTS=False
2025-03-31 20:27:13.452 DEBUG (MainThread) [zigpy_znp.uart] Setting serial pin states: DTR=False, RTS=True
2025-03-31 20:27:13.605 DEBUG (MainThread) [zigpy_znp.uart] Setting serial pin states: DTR=False, RTS=False
2025-03-31 20:27:13.759 DEBUG (MainThread) [zigpy_znp.api] Sending request: SYS.Ping.Req()
2025-03-31 20:27:14.260 DEBUG (MainThread) [zigpy_znp.api] Sending CC253x bootloader skip bytes
2025-03-31 20:27:16.766 DEBUG (MainThread) [zigpy_znp.api] Sending request: SYS.Ping.Req()
2025-03-31 20:27:17.768 DEBUG (MainThread) [zigpy_znp.api] Sending request: SYS.Ping.Req()
2025-03-31 20:27:18.769 DEBUG (MainThread) [zigpy_znp.api] Sending request: SYS.Ping.Req()
2025-03-31 20:27:19.771 DEBUG (MainThread) [zigpy_znp.api] Sending request: SYS.Ping.Req()
2025-03-31 20:27:20.772 DEBUG (MainThread) [zigpy_znp.api] Sending request: SYS.Ping.Req()
2025-03-31 20:27:21.775 DEBUG (MainThread) [zigpy_znp.api] Sending request: SYS.Ping.Req()
2025-03-31 20:27:22.775 DEBUG (MainThread) [zigpy_znp.api] Sending request: SYS.Ping.Req()
2025-03-31 20:27:23.298 DEBUG (MainThread) [zigpy_znp.api] Connection to /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_ea1283213bb6ed118cf4d40ea8669f5d-if00-port0 failed, cleaning up
2025-03-31 20:27:23.301 DEBUG (MainThread) [zigpy.serial] Waiting for serial port to close
2025-03-31 20:27:23.307 DEBUG (MainThread) [zigpy.serial] Connection lost: None
2025-03-31 20:27:23.418 DEBUG (MainThread) [homeassistant.components.zha] Failed to set up ZHA
Does somebody know what could be the cause of that ?
I’m replying to my own post in case someone has the same issue…
My dongle wasn’t properly flash it seems… I used the sonoff tool online to flash it back to the latest firmware and is now detected correctly by ZHA.
You can find the Sonoff online flasher here : SONOFF Dongle Quick Flasher | SONOFF Official
