I’m trying to switch between two pages (main_page and page_1), defined in the LGVL, with a tactile switch. I’m not able to get this working. Tried different ways, but always end up with compile errors. I’m using a gc9a01 display.
I’m new to using displays in esphome…
What am I doing wring here? (this can’t be that hard… I guess…)
# Include all required packages / functions
packages:
base: !include common/base.yaml
hass: !include common/home_assistant.yaml
board: !include common/board_esp32_s2_mini.yaml
wifi: !include common/wifi.yaml
display: !include common/display_gc9a01a_lvgl.yaml
binary_sensor:
- platform: gpio
pin: GPIO18
on_press:
- lambda: |-
static bool is_main_page = true;
is_main_page = !is_main_page;
if (is_main_page) {
lv_scr_load(main_page); // Verwijst naar de object ID for main_page
} else {
lv_scr_load(page_1); // Verwijst naar de object ID for Page_1
Display.yaml:
# GC9A01 round Display 240x240
# initial version: 16022025
font:
- file: "fonts/Roboto-Medium.ttf"
size: 56 # Increased from 24 to 48
extras:
- file: "fonts/materialdesignicons-webfont.ttf"
glyphs: [
"\U000F07E4", # mdi-molecule-co2
"\U000F0F55", # mdi-home-thermometer-outline
- file: "fonts/ds-digi.ttf"
size: 72 # Increased from 12 to 20
# # SPI-bus voor het GC9A01-display
spi:
clk_pin: 11 #5 # SCL
mosi_pin: 9 #3 #SDA
display:
- platform: ili9xxx
model: GC9A01A
dimensions:
height: 240
width: 240
cs_pin: 5 #7
dc_pin: 7 #9
reset_pin: 3 #11
invert_colors: true
rotation: 0
auto_clear_enabled: false
update_interval: never
data_rate: 40MHz
lvgl:
log_level: INFO
color_depth: 16
bg_color: 0x000000
align: center
pad_all: 5
pages:
- id: main_page
widgets:
- meter:
height: 240
width: 240
align: center
text_font: montserrat_14
bg_opa: TRANSP
text_color: 0x999999
border_width: 0
pad_all: 4
scales:
- ticks:
width: 2
count: 21
length: 15
color: 0x000000
major:
stride: 5
width: 6
length: 20
color: 0xFFFFFF
label_gap: 20
range_from: 300
range_to: 2300
angle_range: 270
rotation: 135
indicators:
- line:
width: 8
color: 0xFF0000
r_mod: -5
- arc: # GREEN
color: 0x00FF00
width: 12
start_value: 300
end_value: 800
- arc: #YELLOW
color: 0xFFDE21
width: 12
start_value: 800
end_value: 1299
- arc: # ORANGE
color: 0xFF7518
width: 12
start_value: 1300
end_value: 1799
- arc: #RED
color: 0xF44336
width: 12
start_value: 1800
end_value: 2300
- obj:
# to cover the middle part of meter indicator line
height: 118
width: 118
radius: 73
align: CENTER
border_width: 0
bg_color: 0x000000
pad_all: 0
- label:
text_font: roboto_medium
align: center
bg_opa: TRANSP
y: -35
recolor: true
text: "\U000F07E4"
- label:
text_font: font_digital
align: center
text_color: 0xFFFFFF
bg_opa: TRANSP
y: +12
text: "---"
- label:
text_font: montserrat_24
align: center
bg_opa: TRANSP
y: +90
text: "PPM"
- id: page_1
widgets:
- obj:
height: 118
width: 118
radius: 73
align: CENTER
border_width: 0
bg_color: 0x000000
pad_all: 5
- label:
align: top_left
text_color: 0x0000FF
bg_opa: TRANSP
y: -60
text: "---°C"
- label:
align: top_right
bg_opa: TRANSP
y: -60
text: "---% RH"
top_layer:
widgets:
- obj: # make sure it's the last one in this list:
x: 0
y: 0
width: 100%
height: 100%
bg_color: 0xffffff
bg_opa: COVER
radius: 0
pad_all: 0
border_width: 0
widgets:
- image:
align: CENTER
src: boot_logo
y: -40
- spinner:
align: CENTER
y: 95
height: 50
width: 50
spin_time: 1s
arc_length: 60deg
arc_width: 8
indicator:
arc_color: 0x18bcf2
arc_width: 8
on_press:
- lvgl.widget.hide: boot_screen
