I’m not able to update any integration. My setup work but when I try to update noting happandes. I got this problem when i update to 2026.4.2 and therfore I downgrade to 2026.3.2 but still problem. I tried several reboot (full reboots) but still the same problem.
I don’t get any bug i the log file but trough the dev tool i my explorer i get this
I’m unable to update any integrations. My setup works, but when I try to update, nothing happens.
The issue started when I updated to version 2026.4.2, so I downgraded to 2026.3.2, but the problem still persists.
I’ve tried several full reboots, but it hasn’t helped.
I don’t see any errors in the log files, but when I check the developer tools in my browser, I get this:
Any idea?
card-mod.js:5 Uncaught (in promise) TypeError: Cannot read properties of undefined (reading 'then') at customElements.whenDefined.then.e.showDialog (card-mod.js:5:5232) at at.i (card-mod.js?hacstag=190927524343:1:53299) at d (make-dialog-manager.ts:175:19)
||customElements.whenDefined.then.e.showDialog|@|card-mod.js:5|
||i|@|card-mod.js?hacstag=190927524343:1|
||d|@|make-dialog-manager.ts:175|
||await in d|||
||_handleMoreInfo|@|more-info-mixin.ts:29|
||(anonymous)|@|more-info-mixin.ts:22|
||r|@|fire_event.ts:75|
||_openMoreInfo|@|ha-config-updates.ts:172|
Quick update: the issue was caused by card-mod. Updating to the latest release resolved the problem.
opened 08:47PM - 06 Mar 26 UTC
### My Home Assistant Version
Home Assistant Core: 2026.3.0
Card-mod: 4.2.1
Fro… ntend: 20260228.0
Lovelace configuration: YAML (theme-based)
### My card-mod installation method
HACS
### My lovelace configuration method
YAML
### What I am doing
I'm trying to vertical center more-info-yaml popups in theme.yaml with the new core.
This is what I had before, and it was working:
card-mod-more-info-yaml: |
.mdc-dialog__container {
display: flex !important;
justify-content: center !important;
align-items: center !important;
`card-mod-more-info-yaml` does not work in Home Assistant 2026.3+?
Card-mod fails to inject ANY `<card-mod>` element into the more-info dialog DOM, making it impossible to apply custom styles to more-info dialogs.
Browser Mod custom popups is working:
```yaml
browser_mod:
service: browser_mod.popup
popup_styles:
- style: all
styles: |
ha-dialog {
--dialog-surface-margin-top: auto !important;
Browser Mod popups can be styled and centered.
What seems to not working:
Any `card-mod-more-info-yaml` targeting
- Root element targeting (`:host`, `.`)
- Shadow DOM chains (`$ $ $`)
- Internal element targeting (`ha-more-info-info $`)
- Debug mode (`card-mod-more-info-yaml` with debug)
**Nothing creates a `<card-mod>` element in more-info dialogs.**
### What I expect to happen
When `card-mod-more-info-yaml` is defined in a theme, card-mod should:
1. Inject a `<card-mod>` element into the more-info dialog's shadow DOM
2. Apply the specified styles to the dialog and its children
3. Allow customization of dialog positioning, appearance, and behavior
**February 2026** (3 weeks ago) - Users still using old `.mdc-dialog` syntax, suggesting recent breaking change.
### What happened instead
## Actual Behavior
**Card-mod does NOT inject any `<card-mod>` element whatsoever into `<ha-more-info-dialog>`.**
### Minimal steps to reproduce
## Minimal Reproduction
**themes/test.yaml:**
```yaml
test-theme:
card-mod-theme: test-theme
# These work fine on more-info dialogs ✅
ha-dialog-scrim-backdrop-filter: blur(2px)
mdc-dialog-scrim-color: rgba(0,0,0,0.05)
ha-dialog-border-radius: 12px
dialog-box-shadow: 0px 10px 30px 5px rgba(0, 0, 0, 0.3)
# This is completely ignored - no element created ❌
:host {
--test-variable: red !important;
**Steps to reproduce:**
1. F12 → Inspect `<ha-more-info-dialog>`
2. Search for `<card-mod>` element
3. **Result: NOT FOUND**
### Include any yaml code here
```YAML
## All Attempted Solutions (ALL FAILED)
# Attempt 1: Simple root targeting
:host {
--test: red;
# Attempt 2: Direct dialog targeting
ha-dialog $ wa-dialog $: |
dialog {
margin: auto !important;
# Attempt 3: Full shadow DOM chain
ha-adaptive-dialog $ ha-dialog $ wa-dialog $: |
dialog {
top: 50% !important;
transform: translateY(-50%) !important;
# Attempt 4: Broken chain (per troubleshooting docs)
ha-adaptive-dialog $:
ha-dialog $:
wa-dialog $: |
dialog {
# Attempt 5: Targeting internal elements
ha-more-info-info $ more-info-content $: |
.container {
color: red !important;
### Error messages from the browser console
```console
### By checking each box below I indicate that I ...
- [x] Understand that this is a channel for reporting bugs, not a support forum (https://community.home-assistant.io/).
- [x] Have made sure I am using the latest version of the plugin.
- [x] Have searched Home Assistant logs for any relevant card-mod errors or warnings.
- [x] Have followed the troubleshooting steps of the "Common Problems" section of https://github.com/thomasloven/hass-config/wiki/Lovelace-Plugins.
- [x] Understand that failure to follow the template above may increase the time required to handle my bug-report, or cause it to be closed without further action.
