That means you are running supervised which is deprecated.
There is some issue with that at the moment (besides the removal of support in 2 weeks) something to do with a problem with a Docker CE update that recently happened and you need to downgrade, not sure. None of this is supported any longer, so I don’t know. The problem after the update to 2025.11.2 - #3 by Tamsy
