I’m trying to update my supervisor and perpetually getting the following error. OS version is already at 8.4, Core is at 2022.6.7. Running on Proxmox. All prior updates installed without issue. Installation reports as “unhealthy” due to supervisor failing to update.
Logger: homeassistant.core
Source: components/hassio/update.py:256
First occurred: 9:13:38 PM (1 occurrences)
Last logged: 9:13:38 PM
Error executing service: <ServiceCall update.install (c:01G9GM5K28TG9NBFS45H1EGXV0): entity_id=['update.home_assistant_supervisor_update'], backup=False>
File "/usr/src/homeassistant/homeassistant/components/hassio/update.py", line 254, in async_install
await async_update_supervisor(self.hass)
File "/usr/src/homeassistant/homeassistant/components/hassio/handler.py", line 47, in _wrapper
raise HassioAPIError(data["message"])
homeassistant.components.hassio.handler.HassioAPIError: Update of Supervisor failed: Can't install ghcr.io/home-assistant/amd64-hassio-supervisor:2022.07.0: 500 Server Error for http+docker://localhost/v1.41/images/create?tag=2022.07.0&fromImage=ghcr.io%2Fhome-assistant%2Famd64-hassio-supervisor&platform=linux%2Famd64: Internal Server Error ("Get "https://ghcr.io/v2/": context deadline exceeded")
File "/usr/src/homeassistant/homeassistant/core.py", line 1722, in catch_exceptions
await coro_or_task
File "/usr/src/homeassistant/homeassistant/core.py", line 1741, in _execute_service
await cast(Callable[[ServiceCall], Awaitable[None]], handler.job.target)(
File "/usr/src/homeassistant/homeassistant/helpers/entity_component.py", line 204, in handle_service
await service.entity_service_call(
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 680, in entity_service_call
future.result() # pop exception if have
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 964, in async_request_call
await coro
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 717, in _handle_entity_call
await result
File "/usr/src/homeassistant/homeassistant/components/update/__init__.py", line 152, in async_install
await entity.async_install_with_progress(version, backup)
File "/usr/src/homeassistant/homeassistant/components/update/__init__.py", line 411, in async_install_with_progress
await self.async_install(version, backup)
File "/usr/src/homeassistant/homeassistant/components/hassio/update.py", line 256, in async_install
raise HomeAssistantError(
homeassistant.exceptions.HomeAssistantError: Error updating Home Assistant Supervisor: Update of Supervisor failed: Can't install ghcr.io/home-assistant/amd64-hassio-supervisor:2022.07.0: 500 Server Error for http+docker://localhost/v1.41/images/create?tag=2022.07.0&fromImage=ghcr.io%2Fhome-assistant%2Famd64-hassio-supervisor&platform=linux%2Famd64: Internal Server Error ("Get "https://ghcr.io/v2/": context deadline exceeded")
