Unable to update to 22.10.0 on RPI?
Hello!
I recently installed HA on an RPI 3b and it’s been going great. Recently I have 3 notifications in settings to update various components.
When I try to update the HomeAssistantSupervisor component, I get the following errors in the log:
  File "/usr/src/homeassistant/homeassistant/components/hassio/update.py", line 254, in async_install
    await async_update_supervisor(self.hass)
  File "/usr/src/homeassistant/homeassistant/components/hassio/handler.py", line 45, in _wrapper
    raise HassioAPIError(data["message"])
homeassistant.components.hassio.handler.HassioAPIError: Update of Supervisor failed: Can't install ghcr.io/home-assistant/aarch64-hassio-supervisor:2022.10.0: 500 Server Error for http+docker://localhost/v1.41/images/create?tag=2022.10.0&fromImage=ghcr.io%2Fhome-assistant%2Faarch64-hassio-supervisor&platform=linux%2Farm64: Internal Server Error ("Get "https://ghcr.io/v2/": net/http: request canceled while waiting for connection (Client.Timeout exceeded while awaiting headers)")
  File "/usr/src/homeassistant/homeassistant/core.py", line 1756, in catch_exceptions
    await coro_or_task
  File "/usr/src/homeassistant/homeassistant/core.py", line 1775, in _execute_service
    await cast(Callable[[ServiceCall], Awaitable[None]], handler.job.target)(
  File "/usr/src/homeassistant/homeassistant/helpers/entity_component.py", line 204, in handle_service
    await service.entity_service_call(
  File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 676, in entity_service_call
    future.result()  # pop exception if have
  File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 931, in async_request_call
    await coro
  File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 713, in _handle_entity_call
    await result
  File "/usr/src/homeassistant/homeassistant/components/update/__init__.py", line 152, in async_install
    await entity.async_install_with_progress(version, backup)
  File "/usr/src/homeassistant/homeassistant/components/update/__init__.py", line 411, in async_install_with_progress
    await self.async_install(version, backup)
  File "/usr/src/homeassistant/homeassistant/components/hassio/update.py", line 256, in async_install
    raise HomeAssistantError(
homeassistant.exceptions.HomeAssistantError: Error updating Home Assistant Supervisor: Update of Supervisor failed: Can't install ghcr.io/home-assistant/aarch64-hassio-supervisor:2022.10.0: 500 Server Error for http+docker://localhost/v1.41/images/create?tag=2022.10.0&fromImage=ghcr.io%2Fhome-assistant%2Faarch64-hassio-supervisor&platform=linux%2Farm64: Internal Server Error ("Get "https://ghcr.io/v2/": net/http: request canceled while waiting for connection (Client.Timeout exceeded while awaiting headers)")
Does anyone have any suggestions for how to proceed? This is a totally standard install from what I can tell.
If I try to update the HomeAssistantCore component I’m told the system isn’t healthy but I don’t get any more detail than that.
Thanks!
I am having a similar problem and can’t figure out how to fix it
are you running on a “supported” operating system?
(You can check it here: http://YOUR_HA_IP:8123/hassio/system/info )
I am not and I saw similar issues.
I was able to work around it.
I was running on Raspbian GNU/Linux 10 (buster) and I had to upgrade to Raspbian GNU/Linux 11 (bullseye) to fix the issue.
The process is explained here: How to Upgrade Raspberry Pi OS from Buster to Bullseye
For me, I think the root cause was that Repository 'http://raspbian.raspberrypi.org/raspbian buster InRelease' changed its 'Suite' value from 'stable' to 'oldstable'
You can see this when you do sudo apt update
hope this helps.,
/chrisV
