Unable to upgrade homeassistant. Still in same release (or am I?)
I am trying to update from 0.84.6 to current version i.e. 0.93.1.
After following the commands below, nothing happens, pip3 stops working and I am still in same version. Any ideas?
pip3 install --upgrade homeassistant
I fixed pip3 not working with following thread: https://stackoverflow.com/questions/49836676/error-after-upgrading-pip-cannot-import-name-main
Did you switch to user homeassistant and activate the virtual environment before running this command? See
https://www.home-assistant.io/docs/installation/hassbian/common-tasks/#update-home-assistant
That was it. Thanks for the link.
