Unable to use Font
Hello, could someone tell me what is wrong with this code?
I went through Display Component — ESPHome and Font Renderer Component — ESPHome several times and couldn’t figure out why I’m getting the error
i2c:
  sda: 5
  scl: 4
  scan: true
font:
  - file: "fonts/Comic Sans MS.ttf"
display:
  - platform: ssd1306_i2c
    setup_priority: -100
    model: "SSD1306 128x64"
    address: 0x3C
    pages:
      - id: page1
        lambda: |-
          it.printf(3, 20, id(my_font), "Acqua Callidus");
INFO ESPHome 2024.7.0
INFO Reading configuration config/test.yaml...
Failed config
font: [source config/test.yaml:37]
  not a valid value.
  - file: fonts/Comic Sans MS.ttf
Looks ok. Try to use file name without spaces. Just guessing, not sure.
Do You have no this font file Comic Sans MS.ttf in fonts directory ?
fontsdirectory to be created in same place where YAML config placed.
Yes, I tried with a single word filename, like arial.ttf and all fonts are in the fonts directory alongside with the config yaml file
marco@arch-marco  ~/Projects/esphome/config  tree
├── fonts
│   ├── BebasNeue-Regular.ttf
│   ├── Comic Sans MS.ttf
│   ├── arial.ttf
│   └── slkscr.ttf
├── secrets.yaml
└── test.yaml
Same problem:
font:
  #- file: "gfonts://Roboto"
  - file: fonts/Roboto-Thin.ttf
I find solution - you need to install “pillow==10.2.0” (with other versions of pillow I got same error)
