Unauthorized login attemps
i’m exposing lovelace to internet access by allowing port forwarding through the router. as a result, I can see attempts to login to lovelace from ips which i want to block. looking for suggested ways to achieve that. was thinking about blocking ip ranges but not sure what to use for that and if that’s the best approach.
https://www.home-assistant.io/integrations/http/#ip_ban_enabled
thanks - looks good enough. is there a way to block login attempts from ip ranges up front?
You can add ip addresses to the ip_bans.yaml file. Not sure if it takes ranges (i.e. nnn.nnn.nnn.nnn/24 ).
