Uncaught error from Chrome... This instance is already constructed
I’ve been getting this error for about 2 weeks now, it fires everytime I refresh/reload a view or the view is refreshed/reloaded. I’m afraid it’s beyond my skillset to understand what it’s trying to tell me, I would appreciate any pointers in the right direction (or an answer if you have one).
Condensed Logs:
Logger: frontend.js.modern.202508111
Source: components/system_log/init.py:331
First occurred: September 1, 2025 at 7:58:18 PM (3 occurrences)
Last logged: September 1, 2025 at 8:57:58 PM
Uncaught error from Chrome 116.0.5845.140 on Windows 10 TypeError: Failed to construct ‘HTMLElement’: This instance is already constructed construct (src/scoped-custom-element-registry.ts:340:21) super (src/reactive-element.ts:1037:4) new i (src/lit-element.ts:130:) super (node_modules/@awesome.me/webawesome/dist/chunks/chunk.ETAGLSDL.js:19:4) super (node_modules/@awesome.me/webawesome/dist/chunks/chunk.I5CT6KOH.js:21:4) N (src/scoped-custom-element-registry.ts:645:4) J (src/scoped-custom-element-registry.ts:408:8) importNode (src/lit-html.ts:1218:51) u (src/lit-html.ts:1639:32) $ (src/lit-html.ts:1475:11)
Raw Logs:
TypeError: Failed to construct 'HTMLElement': This instance is already constructed
Have the same warning. Don’t know what is it…
Currently I’m suspicious of Browser Mod for this error but I haven’t had a chance to test that theory out yet, that’s this weekends chore.
Likely Frontend issue TypeError: Failed to construct 'HTMLElement' - WebView/Android · Issue #26919 · home-assistant/frontend · GitHub. ha-fade-in was recently migrated to use webawesome so issue would have come in at that time.
Browser Mod 2.5.2 did have a similar console error but only on touch devices when tapping interact. This was corrected in 2.5.3. Also to note that Browser Mod does not use webawesome directly in any way.
I see, thanks for that. The posts in that thread all seem to be using android though and I’m using Iridium browser (which has developed its own annoying issues recently) on a desktop. FWIW I wasn’t ready to point fingers yet, it was just a suspicion as Browser Mod is so front end heavy… I am on 2.5.3 and still get the error. Thanks for all your work on Browser Mod BTW.
I’ll update this thread once I have time to investigate (AKA poke it with a stick) this weekend.
Sounds good. I have picked up so many speculations on Browser Mod recently, but it is rarely the issue. It somehow has got a poor name probably because of past issues with many devices etc. All these are now ancient history.
The trace you show is very similar to the issue I posted, especially that webawesome is in the stack.
I am not sure what you mean by Browser Mod being front end heavy. You could say that for card-mod. Browser Mod apllies some Frontend settings in a light way, then just sits there waiting for service commands and responding to activty to update server, but not much at all.
Confirming that HA in safe mode still throws the error, it is definitely a frontend issue and has nothing to do with Browser Mod or any other custom integration/card/whatever.
Thanks for pointing the actual issue out for me @dcapslock, much appreciated.
