After update to 0.113.3, Dark theme toggle switch color not change when uncheck.
If the switch is on it shows no problem by
switch-checked-color: “#00E2D8”
But when in uncheck status, toggle button color is not change.
I use below
switch-unchecked-button-color: “var(–switch-unchecked-color, #00E2D8)”
or
switch-unchecked-button-color: “#00E2D8”
And one more strange thing is in my banner-card, all switch button shows black when uncheck.
In default entity card, it shows light color by default.
Any one can help me?
FYI
Best solution will be I can control the button color by using Theme.
Secondary solution will be just change the black switch toggle button in banner card.
Thanks a lot
For better understanding my issue I attached a screenshot. Sorry for the entity name in Chinese.
Have this added before.
The original theme was using paper-toggle.
It’s no use after update to 0.113 so I add switch-unchecked-button-color.
And after I investigating the code, I find the switch button color in banner-card is using card-background-color.
If I change the card background color the button color also will change.
But it’s a dark theme, not possible to change the card color.
