Hey guys,
I feel a bit ashamed, since I tend to call myself a programmer (mainly C#, SQL and PHP stuff), but I’m having a hard time getting the result that I want.
I use the AccuWeather integration, but the right temperature is not an entity, but it’s a state of the intergration. The integration is called ‘weater.thuis’
If successfully extracted the right temperature using:
{{ state_attr("weather.thuis","temperature") }}
Now, what I want seems so simple: I want to use THAT value on my dashboard to show (and plot) the right temperature. But whatever I try, I can’t seem to understand how to do it.
Currently I have an sensor.yaml file with integration for HP_ILO and that works perfectly. Truthfully: copy pasted from someone else. I tried adding all kinds of code to be able to have a new entity (I guess?) so I could attach that to a card on my dashboard. This is the code I currently have:
friendly_name: Temperature at Home
unit_of_measurement: "°C"
value_template: < {{ state_attr("weather.thuis","temperature") }}
But this does not seem to work.
What is the right code for this template? And how do I use it in my dashboard?
Thanks, guys! I’m sure if I understand this part, I’m really starting to understand the depths of Home Assistant!
