Hello everyone,
A few weeks ago I opened an issue to the zha devs as I bought a Tuya Siren for which no entities or sensors appeared. The issue was implemented as you can see in the link below:
Tuya Siren (new) TS0601 by _TZE284_nlrfgpny · Issue #3667 · zigpy/zha-device-handlers
It appears now in the zha handlers repository ( _TZE284_nlrfgpny):
zha-device-handlers/zhaquirks/tuya/tuya_siren.py at dev · zigpy/zha-device-handlers
However, I already modified my configuration.yml file to enable custom quirks (in fact one custom quirk for a thermostat works fine):
Enable custom quirks
zha:
enable_quirks: true
custom_quirks_path: /config/custom_components/zha_quirks
The problem is that when I reboot HA I see the following error message:
`Unexpected exception importing custom quirk ‘tuya_siren’
File “/usr/local/lib/python3.13/site-packages/zhaquirks/init.py”, line 479, in setup
spec.loader.exec_module(module)
File “”, line 1026, in exec_module
File “”, line 488, in _call_with_frames_removed
File “/config/custom_components/zha_quirks/tuya_siren.py”, line 7, in
from zhaquirks.const import BatterySize
ImportError: cannot import name ‘BatterySize’ from ‘zhaquirks.const’ (/usr/local/lib/python3.13/site-packages/zhaquirks/const.py)`
I saw that in the zha repository there’s a const.py file with the BatterySize enum but I don’t know where I have to put it as in my HA filesystem there is no such path (/usr/local/lib/python3.13/site-packages/zhaquirks).
If I pair the device I cannot see entities or sensors (as before the implementation of the custom quirk) so I guess that error is not allowing me to use it properly. Any hint?
My HA version is the latest one:
- Core: 2025.1.4
- Supervisor: 2024.12.3
- Operating System: 14.1
- Frontend: 20250109.2
Thanks!
