I have an automation to speak (tts) and notify devices if a sensor detects humidity. Sensor is irrelevant (Ikea, MQTT) as it works.
I want it to repeat the message “Water leak in…” every 30 seconds until sensor gets dry.
I first set it to speak/notify, then enter a “while (sensor wet)” loop to speak/notify then wait 30 seconds.
That works.
Then I thought the first speak/notify is redundant, as the one inside the while loop should be enough. Here’s the rub: if I disable the speak/notify before the “while” then the one inside the “while” doesn’t work.
I suspect that the next call happens before the tts finishes but why would that depend on what’s before the loop?
Log includes things like “SpeakScript turned off triggered by automation AutomationName triggered by state of SensorName”
I tried direct tts “calls”, separate scripts to call the TTS, even script for the 30s delay (instead of just the delay) in the hope that scripts would wait for each other.
The code below works, but doesn’t if I disable the “scriptandnotifydevices” before the “repeat”:
alias: ZigIkeaWater1-Wet_Test
description: ""
triggers:
- trigger: state
entity_id:
- binary_sensor.zigikeawater1_water_leak
to: "on"
conditions: []
actions:
- action: media_player.volume_set
metadata: {}
volume_level: 0.31
entity_id: media_player.cat_s_bedroom_speaker
enabled: true
- action: script.scriptspeakandnotifydevices
metadata: {}
message: Water leak in "{{ location }}"
enabled: true
- repeat:
sequence:
- action: script.speakmessage
metadata: {}
alias: "Call script SpeakMessage: \"Water leak in...\""
- action: script.scriptwait30s
metadata: {}
data: {}
while:
- condition: state
entity_id: binary_sensor.zigikeawater1_water_leak
state: "on"
metadata: {}
message: No more water leak in "{{ location }}"
alias: "Script SpeakAndNotify: \"No more Water leak in...\""
mode: single
variables:
It’s hard to say without the code, but the only way I can think of to explain what you’re seeing is if the script called inside the loop somehow depends on the other script to do something.
In fact, to analyze further, the way it works, I should hear it speak twice, one after another: the one before the loop, and the one inside the loop, and only then there should be repeats after 30 seconds. Instead, I hear “Water leak…” at 30s intervals from the beginning, as long as the sensor is on.
The “No more water leak…” always works.
I don’t know how to say it differently. Neither works as “theoretically” expected, but if the speak/notify before the loop is enabled then the result is speak every 30 seconds, EVEN THOUGH there should be 2 speaks at the beginning: the one before the loop and the first inside loop.
The play media TTS calls don’t wait for the TTS to complete (at least in the Sonos integration); so doing two in a row just causes the second one to play; because the first one will play for 1ms, before getting replaced by the second one. Change the text and hear what happens.
What I do is have an automation the reads off an event queue and it then sends the announcement to the speaker; delays for 10 seconds then gets the next one. All my other automations send events to this automation to have stuff announced.
AND it gets worse.
It feels like Home Assistant keeps something about deleted automations somewhere, or else I can’t explain the following.
I was testing the 2 ways above in “ZigIkeaWater1-Wet” and “ZigIkeaWater2-Wet”. the 2 was the one that didn’t work.
Well, after I got 1 to work, I deleted “ZigIkeaWater2-Wet”, duplicated “ZigIkeaWater1-Wet”, edited the "1"s into "2"s, so it became the new “ZigIkeaWater2-Wet”. Regardless, 2 doesn’t work.
I know the duplication should work because I also made “ZigIkeaWater3-Wet” and “ZigIkeaWater4-Wet” which work fine.
So what can I think now?
Yesterday my Home Assistant died.
I restored a backup on a new system and it seems (only tested once for now) that the problem is gone.
I don’t know how but I suspect disk problems for my strange happenings, so thank youse all for trying to help.
