Unifi integration - how to stop it from creating RX and TX sensors for every device?
Hi, I use the Unifi integration for device tracking but don’t need the logs to be inundated with constant RX and TX sensor updates for every device connected to our home wifi.
Is there a way to disable this? The docs don’t seem to have this info.
Go to the configuration/integrations menu and click on the unifi integration. Then in the top right corner there should be a settings message box icon. Click it and turn off newly added entities.
Thank you. That will also stop it from adding new devices that I might want to track… all I want is to not have it add RX and TX sensors. But best solution for now I suppose.
Ok, so that doesn’t work.
I’ve disabled newly added entities.
I’ve tried disabling all of the ones I don’t want in the entities tab. I’ve tried deleting all of the ones I don’t want in the same tab.
Home Assistant keeps repopulating all of the entities.
There’s an issue open for it:
