Unifi presence detection not working?
I installed the unifi controller addon. All my APs show up correctly, everything is fine.
Now I’m trying to set up presence detection. But how is this being done correctly? I added the following to configuration.yaml, and get an error:
device_tracker:
  - platform: unifi
    #host: 192.168.178.109
    username: myuser
    password: mypw
I tried with and without setting the host. Both produce the following error:
  File "/usr/src/homeassistant/homeassistant/setup.py", line 171, in _async_setup_component
    hass, processed_config
  File "/usr/src/homeassistant/homeassistant/components/device_tracker/__init__.py", line 129, in async_setup
    legacy_platforms = await setup.async_extract_config(hass, config)
  File "/usr/src/homeassistant/homeassistant/components/device_tracker/setup.py", line 112, in async_extract_config
    f"Unable to determine type for {platform.name}: {platform.type}"
ValueError: Unable to determine type for unifi: None
I have no device_tracker.yaml set up so far, and the file is not present.
What I noticed: under Configuration > Integrations, I don’t see the Unifi Controller listed. I can only see and access it via the Add-On tab. Is that correct? Or should it be listed in Integrations? If yes, how can I achive this?
I suggest you read the docs.
