UniFi protect integration not connecting to UDMPROSE
I am attempting to add the UniFi protect integration and having absolutely no luck. When I add it through the front-end I get the “unknown error occurred”.
I’m running home assistant in docker (HASSOS).
Ha version 2024.6.0
UniFiOS is version 3.2.12
Protect is version 4.0.33
Log shows this error
Logger: aiohttp.server
Source: /usr/local/lib/python3.12/site-packages/aiohttp/web_protocol.py:421
First occurred: 18:07:52 (15 occurrences)
Last logged: 20:28:57
Error handling request
  File "/usr/local/lib/python3.12/site-packages/aiohttp/web_protocol.py", line 452, in _handle_request
    resp = await request_handler(request)
  File "/usr/local/lib/python3.12/site-packages/aiohttp/web_app.py", line 543, in _handle
    resp = await handler(request)
  File "/usr/local/lib/python3.12/site-packages/aiohttp/web_middlewares.py", line 114, in impl
    return await handler(request)
  File "/usr/src/homeassistant/homeassistant/components/http/security_filter.py", line 92, in security_filter_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/forwarded.py", line 83, in forwarded_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/request_context.py", line 26, in request_context_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/ban.py", line 85, in ban_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/auth.py", line 242, in auth_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/headers.py", line 32, in headers_middleware
    response = await handler(request)
  File "/usr/src/homeassistant/homeassistant/helpers/http.py", line 73, in handle
    result = await handler(request, **request.match_info)
  File "/usr/src/homeassistant/homeassistant/components/http/decorators.py", line 81, in with_admin
    return await func(self, request, *args, **kwargs)
  File "/usr/src/homeassistant/homeassistant/components/config/config_entries.py", line 222, in post
    return await super().post(request, flow_id)
  File "/usr/src/homeassistant/homeassistant/components/http/data_validator.py", line 70, in wrapper
    return await method(view, request, data, *args, **kwargs)
  File "/usr/src/homeassistant/homeassistant/helpers/data_entry_flow.py", line 122, in post
    result = await self._flow_mgr.async_configure(flow_id, data)
  File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 368, in async_configure
    result = await self._async_configure(flow_id, user_input)
  File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 414, in _async_configure
    result = await self._async_handle_step(
  File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 517, in _async_handle_step
    result: _FlowResultT = await getattr(flow, method)(user_input)
  File "/usr/src/homeassistant/homeassistant/components/unifiprotect/config_flow.py", line 343, in async_step_user
    nvr_data, errors = await self._async_get_nvr_data(user_input)
  File "/usr/src/homeassistant/homeassistant/components/unifiprotect/config_flow.py", line 271, in _async_get_nvr_data
    bootstrap = await protect.get_bootstrap()
  File "/usr/local/lib/python3.12/site-packages/pyunifiprotect/api.py", line 1132, in get_bootstrap
    return Bootstrap.from_unifi_dict(**data, api=self)
  File "/usr/local/lib/python3.12/site-packages/pyunifiprotect/data/base.py", line 127, in from_unifi_dict
    data = cls.unifi_dict_to_dict(data)
  File "/usr/local/lib/python3.12/site-packages/pyunifiprotect/data/bootstrap.py", line 224, in unifi_dict_to_dict
    return super().unifi_dict_to_dict(data)
  File "/usr/local/lib/python3.12/site-packages/pyunifiprotect/data/base.py", line 376, in unifi_dict_to_dict
    data[key] = cls._clean_protect_obj_dict(
  File "/usr/local/lib/python3.12/site-packages/pyunifiprotect/data/base.py", line 318, in _clean_protect_obj_dict
    items[key] = cls._clean_protect_obj(value, klass, api)
  File "/usr/local/lib/python3.12/site-packages/pyunifiprotect/data/base.py", line 296, in _clean_protect_obj
    return klass.unifi_dict_to_dict(data=data)
  File "/usr/local/lib/python3.12/site-packages/pyunifiprotect/data/devices.py", line 985, in unifi_dict_to_dict
  File "/usr/local/lib/python3.12/site-packages/pyunifiprotect/data/base.py", line 1005, in unifi_dict_to_dict
  File "/usr/local/lib/python3.12/site-packages/pyunifiprotect/data/base.py", line 866, in unifi_dict_to_dict
  File "/usr/local/lib/python3.12/site-packages/pyunifiprotect/data/base.py", line 362, in unifi_dict_to_dict
    data[key] = cls._clean_protect_obj(data[key], unifi_objs[key], api)
  File "/usr/local/lib/python3.12/site-packages/pyunifiprotect/data/devices.py", line 504, in unifi_dict_to_dict
  File "/usr/local/lib/python3.12/site-packages/pyunifiprotect/data/base.py", line 355, in unifi_dict_to_dict
    data[key] = convert_unifi_data(data[key], cls.__fields__[key])
  File "/usr/local/lib/python3.12/site-packages/pyunifiprotect/utils.py", line 251, in convert_unifi_data
    return type_(value)
  File "/usr/local/lib/python3.12/enum.py", line 744, in __call__
    return cls.__new__(cls, value)
  File "/usr/local/lib/python3.12/enum.py", line 1158, in __new__
    raise ve_exc
ValueError: 'IMAGE' is not a valid DoorbellMessageType
No sooner had I posted this I noticed that the last line of the logs is about my doorbell image (despite looking at the log multiple times!). Turning off the doorbell image solved the problem!
You will probably need core 2024.6.2 first. They adopted the new libraries to allow unifi OS 4.0
Yep it’s the custom doorbell image. 2024.6.2 will probably fix that too.
