I have two errors that I think is related.
I get this after reboot, I read that it might apear if you add code in gui/edit in yaml or using vs code, I tried to fix this automation yesterday using both metodes soo its probably my fault isch?
> Source: helpers/entity_platform.py:873
> integration: Automation (documentation, issues)
> First occurred: 12:18:00 (2 occurrences)
> Last logged: 13:02:16
> Platform automation does not generate unique IDs. ID bevattning_schema_intervall already exists - ignoring automation.bevattning_schema_interva ll
The automation
alias: Bevattning — Schema (intervall)
description: ''
triggers:
- at: '10:00:00'
trigger: time
conditions:
- condition: state
entity_id: input_boolean.bevattning_aktiverad
state: 'on'
- condition: template
value_template: >-
{% set last = state_attr('automation.bevattning_schema_intervall',
'last_triggered') %} {% set dagar =
states('input_number.bevattning_intervall_dagar') | int(1) %} {{ last is
none or (now() - last).total_seconds() > (dagar * 86400) - 3600 }}
actions:
- action: script.bevattning_kor_pump
seconds: '{{ states(''input_number.bevattning_tid_sekunder'') | int(10) }}'
The automation is there but this might be the reason I get the second problem, im trying to run a script script.bevattning_kor_pump but get an error: script cant be found, the script is there, I have only that one and the entity is correct,.
The error in traces
Stopped because an error was encountered at 5 May 2026 at 13:35:28 (runtime: 0.00 seconds)
Action script.bevattning_kor_pump not found
The script
alias: Bevattning — Kör pump
description: Hur länge pumpen ska gå.
fields:
sekunder:
description: Hur länge pumpen ska gå (sekunder)
example: 10
variables:
sek: >-
{{ (sekunder | default(states('input_number.bevattning_tid_sekunder')) |
int(10)) }}
sakra_sekunder: "{{ [sek, 60] | min }}"
sequence:
- condition: state
state: "on"
- action: switch.turn_on
entity_id: switch.tr01_bevattningshub
- delay:
seconds: "{{ sakra_sekunder | int }}"
- action: switch.turn_off
mode: single
If I check developer tools action its not there, only a script called script.bevattning_kor_pump_sakert_v2
If I check developer tools States and check the state of my script its called script.bevattning_kor_pump
Not with the pump_sakert_v2 at the end?
I have all the latest installed pure haos on i386 pc.
Thers only one of this automation in automation.yaml
What is going on?
Edit: If I go into the device under mqtt and open the device TR01 Bevattningshub (its a Thidreality waterpump) and there I can see all the info, and a script, I open that script and check its entity and its bevattning_kor_pump_2?? HA somehow added _2 to it, I guess has some old refernce to something that I deleted soo it cant have the same name twice even if its not in use anymore, WHERE the hell is that unused name beeing picked from???
