I want to use the stuff I added to my configuration.yaml to be available in alexa and google assistant as well. but when I try to enable it for these through the UI, I get the notification that the entity has not unique ID and hence cannot be edited through the UI. I’ve searched around for quite some time but could not find a way to bring those devices to alexa.
for example these groups. work fine in home assistant, but can’t get them into alexa.
group:
schlafzimmerfenster:
name: Beide Schlafzimmerfenster
entities:
- cover.schlafzimmerfenster_links
- cover.schlafzimmerfenster_rechts
Alle Fenster:
entities:
- cover.badezimmerfenster
Heizungen:
name: Alle Heizungen
entities:
- climate.workingroom_thermostat
- climate.bathroom_thermostat
- climate.livingroom_thermostat
