Universal Media Player: select source doesn't work when child player is active
Dear community:
I’m having some issues with the universal media play defined below. The player delegate commands to 3 child players depending on the selected source, while everything else works great the select_source command doesn’t work. No matter which child is active, I can see the correct input source and get a list of sources to choose from, however when I click on a new source the script “harmony_power_control” isn’t called.
- platform: universal
  name: Living Room Media Hub
  unique_id: livingroom_mediahub
  device_class: receiver
  state_template: >
    {% set act = state_attr('remote.livingroom_mediahub', 'current_activity') %}
    {% if act in ['IP Radio', 'FM Radio'] %}
      {{ states('media_player.livingroom_radio') | default('playing')}}
    {% elif act == 'Music' %}
      {{ states('media_player.ma_livingroom_musicstreamer_dlna') | default('idle') }}
    {% elif act == 'Movie' %}
      {{ states('media_player.livingroom_zidooplayer') | default('idle') }}
    {% else %}
      {{ states('remote.livingroom_mediahub')}}
    {% endif %}
  attributes:
    source_list: remote.livingroom_mediahub|activity_list
    source: remote.livingroom_mediahub|current_activity
    is_volume_muted: input_boolean.livingroom_mediahub_mute
    volume_level: number.livingroom_mediahub_volume
  children:
    - media_player.ma_livingroom_musicstreamer_dlna
    - media_player.livingroom_zidooplayer
    - media_player.livingroom_radio
  active_child_template: >
    {% set a = state_attr('remote.livingroom_mediahub', 'current_activity') %}
    {% set children = {
      'Music': 'media_player.ma_livingroom_musicstreamer_dlna',
      'Movie': 'media_player.livingroom_zidooplayer',
      'IP Radio': 'media_player.livingroom_radio',
      'FM Radio': 'media_player.livingroom_radio'
    {% set target = children.get(a) %}
    {# Only return the entity if it is actually 'online' (not unavailable/unknown) #}
    {% if target and states(target) not in ['unavailable', 'unknown'] %}
      {{ target }}
    {% else %}
      {# Fallback to a 'safe' state or nothing #}
      none
    {% endif %}
  commands:
    turn_on:
      action: script.turn_on
        entity_id: script.harmony_power_control
        variables:
          power: true
    turn_off:
        variables:
          power: false
    volume_set:
      action: number.set_value
        entity_id: number.livingroom_mediahub_volume
        value: "{{ volume_level }}"
    volume_up:
        value: >
          {% set current = states('number.livingroom_mediahub_volume') | float(0) %}
          {{ [current + 0.02, 1.0] | min }}
    volume_down:
        value: >
          {{ [current - 0.02, 0.0] | max }}
    volume_mute:
      action: script.harmony_toggle_mute
    select_source:
        variables:
          power: true
          activity: "{{ source }}"
The 3 child players:
  1. media_player.ma_livingroom_musicstreamer_dlna: from music assistant integration with supported_features: 7796671
  2. media_player.livingroom_zidooplayer: from zidoo integration and the supported_features: 221115
  3. media_player.livingroom_radio is defined as below with supported_features 16433:
  name: "Living Room Radio"
  unique_id: livingroom_radio
  state_template: >
      {{ 'paused' if is_state('input_boolean.livingroom_mediahub_mute', 'on') else 'playing' }}
    {% else %}
      off
    {% endif %}
  commands:
    media_next_track:
      action: remote.send_command
      target: { entity_id: remote.livingroom_mediahub }
        device: "AV Receiver"
        command: >
          {{ 'Net/UsbRight' if act == 'IP Radio' else 'NextPreset' }}
    media_previous_track:
        command: >
          {{ 'Net/UsbLeft' if act == 'IP Radio' else 'PrevPreset' }}
    media_play:
    media_pause:
    media_play_pause:
What I don’t understand is the select_source command is defined in parent universal player, and my understanding is that if the child player doesn’t support it it falls back to parent - and in fact no matter which child player is playing I can see the correct source and source list.
Any suggestion is appreciated!
Ok, I’m very certain this used to work fine, and in fact the same media player exposed in HomeKit can change source without any issue.
I start to it might be some GUI change to media player card that caused the issue in 2026.02. How can I troubleshoot this?
Edit: it’s confirmed a frontend issue and will be fixed in next release
Thank you!
Been trying for ages to get a new universal media player set up. Turns out it was correct and works if I use the select source action against it from developer tools.
I just downloaded the new version 2026.2.3. But the problem still persists. The sources still won’t switch.
I’m not developer so don’t know if the fix has been merged for this one, if not most likely in 2026.3.
