Universal media player: Support multiple actions for commands like turn_on and turn_off
Currently, universal media players only accept one service action per command.
This request is to add support for multiple service actions per command… notably (but perhaps not exclusively) for the turn_on and turn_off commands.
Note: it is 100% true that the above can be accomplished with scripts. This request is primarily focused on (a) convenience and (arguably) conciseness, and (b) maintaining feature / syntax parity across various similar integrations, many of which have already enabled this capability (e.g. template switch supports multiple actions ).
Given the intent of universal media player to “wrap” / encapsulate multiple child players, it’s not hard to imagine common cases where the turn_on and turn_off might have more than one job to do requiring more than one service action
(E.g. 1+ media_player.turn_on actions for child players, plus a cover.close for a projector screen or window covering…)
Again the above is known to be possible by implementing the universal player’s desired behavior outside its config in a separate script. This FR requests the abiliy to implement such behaviors directly in the media player config.
You want a media.player domain entity to send a command that is meant for the cover domain?
Good luck with your request, but what you’re requesting is extremely unlikely to be implemented. Us a script or an automation instead.
Ah, that part of my previous post isn’t actually material to of this feature request.
In fact, with or without this FR I think what you are describing is already possible, even if it’s not considered a good practice(?):
media_player:
  platform: universal
  name: Already Supported Cross-Domain Action Example
  children:
    - media_player.child_entity_id
  commands:
    turn_on:
      action: cover.close # could be _any_ service action / any domain -- not relate to this FR
        entity_id: cover.projector_screen
This feature request is intended to expand the syntax that is expected / allowed for each individual entry under the universal player’s commands config variable.
I believe the individual config entries under commands: each specify an override for some matching command(s) on the child media_player. What I am requesting here is to expand the allowed syntax for each such override:
  • Already supported in 2025.4.3:
    • Accept any single action for each command override, as above
  • Requested change in this FR: also accept multiple actions for each command override
There are existing patterns enabling the above in other “wrapper-like” integrations, one of which which could be mirrored to support this FR. For exmaple:
  • @tom_l pointed out that e.g. Template Switch config variables like turn_on will accept an “action or list of actions”. This pattern offers a straightforward way to enable multiple actions per config entry, and better aligns universal media player’s config with other similar integrations in terms of feature / syntax parity.)
    That approach would satisfy this FR by enabling something like the following:
    media_player:
      platform: universal
      name: Multiple Actions Example
      children:
        - media_player.child1_entity_id
        - media_player.child2_entity_id
      commands:
        turn_on:  # PROPOSED: allow the following to be a list, as shown (not currently valid)
          - action: media_player.turn_on # PROPOSED: list syntax, first entry
              entity_id: media_player.child1_entity_id
          - action: media_player.turn_on # PROPOSED: list syntax second entry
              entity_id: media_player.child2_entity_id
  • Alternatively(?): I noticed that Template Alarm config variables like disarmappear to accept script syntax: the example YAML shows a list containing both a condition: and an action:
For my purposes, the first syntax (list, but perhaps not full script syntax) would be sufficient – the latter could be useful but, as folks have pointed out, there is always the option of placing more complex behaviors like that in a script.
I’m searching currently exactly for the same!
