2018-10-07 11:47:20 INFO (MainThread) [homeassistant.core] Starting Home Assistant
2018-10-07 11:47:20 INFO (MainThread) [homeassistant.core] Timer:starting
2018-10-07 11:47:31 INFO (MainThread) [homeassistant.components.discovery] Unknown service discovered: igd {‘host’: ‘192.168.0.1’, ‘port’: 1900, ‘ssdp_description’: ‘http://192.168.0.1:1900/igd.xml’, ‘name’: ‘Wireless G Router WR340G’, ‘model_name’: ‘TL-WR340G’, ‘model_number’: ‘4.0’, ‘serial’: None, ‘manufacturer’: ‘TP-LINK’, ‘udn’: ‘uuid:upnp-InternetGatewayDevice-192168015678900001’, ‘upnp_device_type’: ‘urn:schemas-upnp-org:device:InternetGatewayDevice:1’}
There is no error that I can see there. What symptoms of an error are you seeing?
I have router for internet , and hi give me that error or sonething , in regular of an ip to conect to home assist .
Ps : i am suck of c++ or anything else i have instal via tutorials on win 10 .
Your post makes no sense.
It’s not an error. it is an information log (see the “INFO” tag). It just means HA discovery has found your router.
You can add it as a tracked device or set it to be ignored in the discovery configuration.
Or just ignore it. It is causing no harm.
I understand thanks , its a info that good .
But i don t now how to find the ip adress to enter in home assistant that is my problem and i thing is because the router.
happened here too, its the new UPNP/IDG integration that sees it. Its a fine moment to turn off Upnp on your router
