Unknown Z-Wave JS Device/Manufacturer
Running HASSIO on RPi with:
  1. core-2021.4.3
  2. supervisor-2021.03.9
  3. Home Assistant OS 5.13
  4. Aeotec USB Z-Wave Stick 5 (ZW090-A)
I successfully paired an Aeotec NanoMote Quad (4 button remote) to my Z-Wave network but, it’s showing as a generic NODE 51 without any attributes like manufacturer, model, e.t.c. If button 3 is pressed on the remote, logs show:
2021-04-12T08:11:57.499Z CNTRLR « [Node 051] received CentralScene notification {
“nodeId”: 51,
“ccId”: “Central Scene”,
“ccCommand”: “0x03”,
“payload”: “0x3e8003”
I then tried to test if I can set any device config parameters by calling the zwave_js.set_config_parameter. In this case, changing parameter 43 from 0 to 1 which, enables the buzzer alarm when battery is running low. Logs show:
2021-04-12T08:13:06.700Z CNTRLR « [Node 051] Received updated node info
2021-04-12T08:13:06.705Z CNTRLR [Node 051] The node is now awake.
2021-04-12T08:13:06.942Z CNTRLR « [Node 051] node info received
supported CCs:
· Z-Wave Plus Info
· Association
· Association Group Information
· Transport Service
· Version
· Manufacturer Specific
· Device Reset Locally
· Powerlevel
· Battery
· Security
· Security 2
· Wake Up
· Central Scene
· Configuration
· Supervision
· Firmware Update Meta Data
controlled CCs:
· Multilevel Switch
2021-04-12T08:13:06.975Z CNTRLR [Node 051] Interview stage completed: NodeInfo
2021-04-12T08:13:06.980Z CNTRLR » [Node 051] querying securely supported commands…
2021-04-12T08:13:07.165Z CNTRLR « [Node 051] Received updated node info
2021-04-12T08:13:07.291Z CNTRLR « [Node 051] Received updated node info
2021-04-12T08:13:17.324Z CNTRLR [Node 051] Timed out while waiting for a response from the node
2021-04-12T08:13:17.326Z CNTRLR [Node 051] The node is not included securely. Continuing interview non-securel
y.
2021-04-12T08:13:17.367Z CNTRLR [Node 051] Interviewing Manufacturer Specific…
2021-04-12T08:13:17.367Z CNTRLR » [Node 051] querying manufacturer information…
2021-04-12T08:13:25.761Z CNTRLR [Node 051] did not respond after 1/3 attempts. Scheduling next try in 500 ms.
2021-04-12T08:13:34.556Z CNTRLR [Node 051] did not respond after 2/3 attempts. Scheduling next try in 500 ms.
2021-04-12T08:13:43.449Z CNTRLR [Node 051] The node did not respond after 3 attempts.
It is probably asleep, moving its messages to the wakeup queue.
2021-04-12T08:13:43.451Z CNTRLR [Node 051] The node is now asleep.
It appears that the interview revealed several attributes that should’ve been added to the node on my stick. Any ideas?
A battery-operated device can take quite some time or a few manual wake-ups before it’s completely interviewed. The log should move forward between the different stages outlined on Z-Wave Query Stage - Home Assistant (home-assistant.io)
